Learn how to integrate IndiaMART leads with Flodesk subscribers using Pabbly Connect. Follow this step-by-step tutorial for seamless automation. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To create a Flodesk subscriber from IndiaMART leads, you first need to access Pabbly Connect. Start by navigating to the Pabbly Connect website.
If you are an existing user, click on the ‘Sign In’ button. New users should click on ‘Sign Up Free’ to create an account, which takes less than two minutes. After signing in, you will land on the Pabbly Connect dashboard.
Once you are on the Pabbly Connect dashboard, you will need to create a new folder for your workflow. Click on the folder icon and name it ‘Automations for IndiaMART’. This helps in organizing your workflows effectively. using Pabbly Connect
  • Name your workflow as ‘IndiaMART Automation’.
  • Select the folder you created earlier.
After naming your workflow, you will see options for setting up triggers and actions. Select IndiaMART as your trigger application and choose the event ‘New Leads’ to start your automation.
3. Connecting to IndiaMART API
To connect IndiaMART with Pabbly Connect, you will need your API key. Log into your IndiaMART account and head to the settings section. Under account settings, find the ‘CRM API’ option.
Generate your API key if you haven’t already. Copy this key and paste it into the connection field in Pabbly Connect. Click on ‘Save’ to establish the connection. After connecting, click on ‘Save and Send Test Request’ to retrieve the latest lead details from IndiaMART.
4. Setting Up Flodesk in Pabbly Connect
With the IndiaMART API connected, the next step is to set up Flodesk as your action application within Pabbly Connect. Select ‘Create or Update Subscriber’ as the action event.
Click on ‘Connect’ to link your Flodesk account. Grant the necessary permissions when prompted. You will then need to map the fields for creating or updating a subscriber, including their email, first name, and last name.
  • Choose the email field from the lead details.
  • Map the first name and last name using the data retrieved from IndiaMART.
After mapping all required fields, click on ‘Save and Send Test Request’ to check if the subscriber is added successfully in Flodesk.
5. Verifying the Integration
Now that you have set up the workflow, it’s time to verify if the integration was successful. Go to your Flodesk account and check if the subscriber has been added with the correct details.
You should see the subscriber with the name and email address you mapped earlier. This confirms that Pabbly Connect has successfully facilitated the integration between IndiaMART leads and Flodesk subscribers.
In conclusion, using Pabbly Connect allows for seamless automation of creating Flodesk subscribers from IndiaMART leads, enhancing your marketing efficiency.
This tutorial detailed how to create Flodesk subscribers from IndiaMART leads using Pabbly Connect. By following the exact steps provided, you can automate your lead management efficiently.
