Learn how to automate Facebook page posts from Pinterest pins using Pabbly Connect. Follow our step-by-step tutorial to set up your integration seamlessly. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To create Facebook page posts from Pinterest pins, you will first need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing in or signing up for a new account.
Once logged in, you will find the dashboard where you can manage your integrations. Click on the ‘Create Workflow’ button to begin setting up your automation process.
After accessing Pabbly Connect, you can create a new workflow. Name your workflow something descriptive, like ‘Create Facebook Page Post from Pinterest Pins’. Organizing your workflows into folders can help you manage them effectively.
To set up your workflow, follow these steps:
  • Name your workflow and select a folder.
  • Click on ‘Create’ to finalize your workflow setup.
This action sets the stage for defining your trigger and action applications within Pabbly Connect.
Setting Up the Trigger in Pabbly Connect
For this automation, your trigger application will be Pinterest. Select Pinterest as your trigger application and choose the event as ‘New Pin’. This means every time a new pin is created in your Pinterest account, Pabbly Connect will capture this event.
To connect Pinterest with Pabbly Connect, perform the following steps:
  • Click on ‘Connect’ to create a new connection.
  • Select ‘Add New Connection’ and authorize Pabbly Connect to access your Pinterest account.
  • Confirm the connection is successful to proceed.
Once the connection is established, you can generate a new pin in Pinterest to test the setup.
Setting Up the Action in Pabbly Connect
Your action application will be Facebook Pages, where the new pin will be posted. Choose Facebook Pages as your action application and select the event ‘Create Page Post’. This means that whenever a new pin is created in Pinterest, it will automatically be posted on your Facebook page.
To connect Facebook Pages with Pabbly Connect, follow these steps:
Click on ‘Connect’ to establish a connection. Select ‘Add New Connection’ and authorize Pabbly Connect to access your Facebook account. Choose the Facebook page where you want the post to appear.
After the connection is made, you can map the data from Pinterest to Facebook, ensuring that the post includes the title and description from the new pin.
Testing the Integration in Pabbly Connect
Now that you have set up both the trigger and action, it’s time to test your integration. Create a new pin in your Pinterest account and publish it. After publishing, return to Pabbly Connect and click on ‘Save and Send Test Request’ to check if the integration works correctly.
If everything is set up properly, you should see a successful response indicating that the new pin has been posted on your Facebook page. Refresh your Facebook page to confirm that the post appears as expected.
To summarize:
Create a new pin in Pinterest. Return to Pabbly Connect and send a test request. Check your Facebook page for the new post.
This process ensures that your automation is functioning as intended, allowing for seamless posting from Pinterest to Facebook through Pabbly Connect.
In this tutorial, we demonstrated how to automate Facebook page posts from Pinterest pins using Pabbly Connect. By following the steps outlined, you can easily set up this integration and streamline your social media management. Automating these processes saves time and enhances your online presence.
