Learn how to create a Facebook page post from Telegram messages using Pabbly Connect. Follow this detailed tutorial for seamless integration. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To create a Facebook page post from Telegram messages, we will use Pabbly Connect. First, access Pabbly Connect by visiting the website. You can sign in if you are an existing user or sign up for free if you are new. Pabbly Connect offers 100 free tasks every month for new users.
Once signed in, you will see a dashboard with various Pabbly applications. Click on Pabbly Connect to start the integration process. This platform allows you to create workflows that automate tasks between applications without coding.
After accessing Pabbly Connect, click on the ‘Create Workflow’ button. You will need to name your workflow and choose a folder to save it in. For this tutorial, name it ‘How to Create Facebook Page Post from Telegram Messages’ and select the folder named ‘Automations’.
Once the workflow is created, you will enter the workflow window. This window is crucial for setting up your trigger and action. The trigger will be set to activate when a new message is received in Telegram, and the action will be to create a post on Facebook.
  • Click on ‘Create Workflow’ in Pabbly Connect.
  • Name your workflow and select a folder.
  • Enter the workflow window for triggers and actions.
Now that your workflow is set up, you can proceed to select the trigger application, which will be Telegram. This sets the stage for the automation process.
Setting Up the Telegram Trigger in Pabbly Connect
In the workflow window, search for the Telegram bot as your trigger application. Select it and set the trigger event to ‘Set Webhook / Watch Updates’. Click on ‘Connect’ and add a new connection if you haven’t done so already. using Pabbly Connect
To establish this connection, you will need a token from your Telegram account. Open Telegram and use the BotFather to create a new bot. Enter the command ‘/newbot’ and follow the prompts to name your bot and obtain the token.
  • Select Telegram as the trigger application in Pabbly Connect.
  • Set the trigger event to ‘Set Webhook / Watch Updates’.
  • Create a new bot using BotFather to get your token.
Copy the token provided by BotFather and paste it into Pabbly Connect to finalize the connection. Ensure that your bot has admin access in the Telegram group to receive messages.
Setting Up the Facebook Post Action in Pabbly Connect
After configuring the Telegram trigger, it’s time to set up the action for Facebook. In the action application, select Facebook Pages and choose the action event as ‘Create Page Photo Post’. Click on ‘Connect’ to link your Facebook account. using Pabbly Connect
Once connected, select the Facebook page where you want to post the message. You will also need to provide the photo URL. Go back to the previous action step to copy the file ID, which will be used to create the photo post on Facebook.
Select Facebook Pages as the action application. Choose the action event ‘Create Page Photo Post’. Copy the file ID from the previous step for the photo URL.
Finally, map the necessary fields, including the caption from the Telegram message, and click on ‘Save and Send Test Request’ to ensure everything is functioning correctly. This will create a new post on your Facebook page.
Testing the Integration with Pabbly Connect
With the workflow set up, it’s essential to test the integration to ensure it works as intended. Send a test message in your Telegram group, and Pabbly Connect should capture this message and trigger the workflow automatically.
After sending the message, check your Facebook page to confirm that the post has been created with the correct content and image. This step verifies that the integration between Telegram and Facebook via Pabbly Connect is successful.
Send a test message in your Telegram group. Check your Facebook page for the new post. Ensure that the content and image match the Telegram message.
If everything is set up correctly, you will see the new post appear on your Facebook page, confirming that the integration is working seamlessly.
In this tutorial, we explored how to create a Facebook page post from Telegram messages using Pabbly Connect. By setting up a trigger for Telegram messages and an action for Facebook posts, you can easily automate your social media updates.
This integration allows you to streamline your communication and ensure your audience stays informed with the latest updates from Telegram. With Pabbly Connect, you can enhance your productivity through automation.
