Learn how to automate Facebook posts from Pinterest pins using Pabbly Connect. This step-by-step guide covers the entire integration process. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To create Facebook page posts from Pinterest pins, you need to access Pabbly Connect. This platform allows you to automate tasks between different applications seamlessly. Start by visiting the Pabbly Connect website.
Once there, you can either sign up for a free account or log in if you are an existing user. The free plan offers 300 tasks per month, which is perfect for exploring the capabilities of Pabbly Connect.
After signing in to Pabbly Connect, navigate to the dashboard. Here, you will create a new workflow to automate the process of posting to Facebook. Click on the ‘Create Workflow’ button located at the top right corner.
  • Name your workflow as ‘Create Facebook Page Post from Pinterest Pins’.
  • Select the folder for your workflow, such as ‘Automations’.
  • Click the ‘Create’ button to finalize your workflow setup.
With this, your workflow is set up, and you can now define the trigger and action needed to automate the posting process.
In this step, you will set up the trigger for your workflow using Pabbly Connect. Select Pinterest as your trigger application and choose the event as ‘New Pin’. This ensures that every time a new pin is created, the automation will trigger.
To connect your Pinterest account, click on ‘Connect’ and then select ‘Add New Connection’. After authorizing Pabbly Connect to access your Pinterest account, you can proceed to generate a new pin in Pinterest for testing.
Now, it’s time to set up the action that will take place once the trigger is activated. Choose Facebook Pages as your action application and select the event ‘Create Page Post’. This means that whenever a new pin is created, a corresponding post will be made on your Facebook page. using Pabbly Connect
  • Connect your Facebook account by clicking ‘Connect’ and selecting ‘Add New Connection’.
  • Choose the Facebook page where you want to post the new pin.
  • Map the description and image link from your Pinterest pin to the Facebook post.
Once all details are mapped, click ‘Save and Send Test Request’ to ensure everything is functioning correctly.
5. Testing the Integration in Pabbly Connect
With your workflow set up, it’s essential to test the integration using Pabbly Connect. Create a new pin in your Pinterest account to see if the automation works as intended. After publishing the pin, return to Pabbly Connect to check for the successful response.
If everything is set up correctly, you should see the new post on your Facebook page with the same title and description as your Pinterest pin. Refresh your Facebook page to verify the post appears as expected.
This confirms that the integration is working, allowing for automatic posting from Pinterest to Facebook seamlessly through Pabbly Connect.
In this tutorial, we explored how to create Facebook page posts from Pinterest pins using Pabbly Connect. By following the steps outlined, you can automate the process and enhance your social media presence effortlessly.
