Learn how to automate the creation of ConvertKit subscribers for CopeCart payments using Pabbly Connect. Step-by-step guide to streamline your integration process. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Setting Up Pabbly Connect for CopeCart Payments
To automate the creation of ConvertKit subscribers for CopeCart payments, you first need to set up Pabbly Connect. This platform allows you to integrate various applications without any coding skills. Start by visiting the Pabbly Connect homepage and either sign in or sign up for a free account.
After signing in, navigate to the dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow, such as ‘Create ConvertKit Subscriber for CopeCart Payment,’ and select a folder to save it in. This will help you organize your automations efficiently.
2. Defining Trigger and Action in Pabbly Connect
In Pabbly Connect, automation works on the trigger and action principle. For this integration, select CopeCart as the trigger application and ConvertKit as the action application. The trigger event will be set to ‘Instant Payment Notification,’ which means that whenever a payment is made in CopeCart, it will trigger the action in ConvertKit.
- Select CopeCart as the trigger application.
- Choose ‘Instant Payment Notification’ as the trigger event.
- Set ConvertKit as the action application.
After setting up the trigger, Pabbly Connect will provide you with a webhook URL. This URL is essential for connecting your CopeCart account with Pabbly Connect, acting as a bridge for data transfer.
3. Connecting CopeCart to Pabbly Connect
To connect CopeCart with Pabbly Connect, navigate to your CopeCart account settings. Under the settings, find the option for API and connections. Click on ‘New Integration’ and select the type as ‘Generic.’ You will need to provide a name for the integration, like ‘ConvertKit Subscribers,’ and paste the webhook URL from Pabbly Connect into the notification URL field.
Once you have saved the integration, ensure that it is active. You will then need to attach this integration to the product you want to sell. Go to the product section in CopeCart, edit the product, and select the integration you just created. Make sure to save the changes.
4. Setting Up ConvertKit Integration with Pabbly Connect
Now, you need to set up ConvertKit within Pabbly Connect. Choose the action event as ‘Add Subscriber to a Form.’ Click on ‘Connect’ and select ‘Add New Connection.’ You will need to provide your ConvertKit API key and API secret, which can be found in your ConvertKit account settings under the API section.
- Log into your ConvertKit account.
- Navigate to account settings and locate the API section.
- Copy your API key and secret into Pabbly Connect.
After entering your API credentials, select the form where you want to add subscribers. You will then map the customer details received from CopeCart, such as their name and email, to the corresponding fields in ConvertKit. This mapping ensures that each new payment leads to a new subscriber being added automatically.
With everything set up, it’s time to test the integration. Make a test payment in CopeCart for the product you set up earlier. Once the payment is processed, Pabbly Connect will capture the response, including the customer’s details.
Check your ConvertKit account to confirm that the subscriber has been added successfully. You should see the new subscriber with the details you entered during the test payment. This confirms that the integration is working as intended and that every new payment in CopeCart will automatically create a subscriber in ConvertKit.
In summary, using Pabbly Connect allows for seamless integration between CopeCart and ConvertKit. This automation will save you time and ensure that all your new customers are added as subscribers without any manual effort required.
