Learn how to integrate Calendly with ClickUp using Pabbly Connect to automate task creation for new invitees seamlessly. Step-by-step guide included. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To create a ClickUp task for a Calendly invitee, start by accessing Pabbly Connect. This platform allows seamless integration between your Calendly and ClickUp accounts without any programming knowledge.
Open your web browser and search for Pabbly Connect. Once on the landing page, you’ll see options to sign in or sign up for free. If you are a new user, signing up will grant you 100 tasks free each month. Existing users can click on the sign-in button to access their dashboard.
After signing in, navigate to the Pabbly Connect dashboard. Click on the ‘Create Workflow’ button to initiate your integration process. You will be prompted to name your workflow, such as ‘Create ClickUp Task for Calendly Invitee’. using Pabbly Connect
  • Choose a folder to save your workflow.
This action opens the workflow window where you will set up the trigger and action. The trigger is your command, while the action is the response that follows.
3. Setting Up the Trigger with Calendly
In the workflow window, select Calendly as your trigger application. This ensures that whenever a new invite is created in Calendly, it automatically triggers your workflow in Pabbly Connect.
Next, choose the trigger event labeled ‘Invite Created’. Click on the ‘Connect’ button and select ‘Add New Connection’ if you haven’t connected your Calendly account yet. Follow the prompts to establish the connection.
  • Select your organization from the dropdown.
  • Choose the user for whom the invite was created.
After saving, send a test request to capture the response from Calendly. This response will be used in the next steps to create a task in ClickUp.
4. Creating a ClickUp Task as Action
Now it’s time to set up the action by selecting ClickUp as your action application in Pabbly Connect. This action will create a task in ClickUp whenever a new invite is created in Calendly.
Choose the action event ‘Create Task’ and click ‘Connect’. If you haven’t connected ClickUp, you will need to generate an API token from your ClickUp account settings. This token allows Pabbly Connect to communicate with ClickUp.
Select your workspace and space in ClickUp. Map the task name and description using data from the Calendly invite.
Ensure that you map the task details dynamically, so they update with each new invite. After completing the mapping, click ‘Save and Send Test Request’ to verify that the task is created successfully in ClickUp.
5. Finalizing and Testing Your Workflow
Once the task creation step is successfully tested, finalize your workflow by adding any additional settings you may need. This includes setting due dates, priorities, and statuses for the ClickUp tasks based on the invite details.
To ensure everything is working correctly, conduct a final test by scheduling a new event in Calendly. After booking, check ClickUp to confirm that the task has been created with the correct details.
Monitor the workflow to ensure it triggers correctly. Adjust any settings in Pabbly Connect as necessary.
With this, your integration is complete, allowing seamless task creation in ClickUp for every new Calendly invitee.
This tutorial on using Pabbly Connect to create ClickUp tasks for Calendly invitees illustrates how easy it is to automate workflows. By following these steps, you can enhance productivity and streamline your processes effectively.
