Learn how to integrate AWeber and FunnelKit using Pabbly Connect for seamless subscriber management. Follow this step-by-step tutorial to automate your processes. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Accessing Pabbly Connect for AWeber Integration
To create AWeber subscribers from FunnelKit, we will use Pabbly Connect. Start by visiting the Pabbly Connect website, where you can either sign in or sign up for a free account. Signing up is quick and grants you 100 free tasks each month.
Once logged in, navigate to the dashboard. Here, you will find the option to create a new workflow. Click on the ‘Create Workflow’ button, name your workflow, and select a folder to save it. This sets the stage for automating the subscriber creation process.
2. Setting Up the Trigger Event with FunnelKit
In this step, we will set up the trigger event using Pabbly Connect to monitor new users in FunnelKit. Select FunnelKit as your trigger application and choose the event ‘New User’. This event will initiate the workflow whenever a new user is added.
- Select FunnelKit as the trigger application.
- Choose the trigger event ‘New User’.
- Connect FunnelKit to Pabbly Connect using the provided VB URL.
After selecting the trigger event, you will be prompted to connect FunnelKit using the VB URL. Copy this URL and proceed to your WordPress account where FunnelKit is installed. Use this URL to set up the automation in FunnelKit.
3. Creating Automation in FunnelKit
Next, navigate to your WordPress account and open the FunnelKit plugin. Click on the ‘Add New Automation’ button to create a new automation that will send user data to Pabbly Connect. Name your automation and select the trigger as ‘User Created’.
In this automation, you’ll set the action to send data to Pabbly Connect. Paste the copied VB URL in the designated field and start adding the user data you wish to send. This includes username, first name, last name, and email address.
- Add the necessary user data fields: username, first name, last name, email.
- Use merge tags to populate user data dynamically.
- Save the automation and make it active.
Once this setup is complete, any new user created in FunnelKit will automatically trigger the data to be sent to Pabbly Connect.
4. Setting Up the Action Event with AWeber
Now that the trigger is set, we will configure the action event in Pabbly Connect to create a new subscriber in AWeber. Select AWeber as your action application and choose the event ‘Add or Update Subscriber’.
To connect AWeber to Pabbly Connect, you will need to enter your AWeber login details. After successfully connecting, you will be prompted to fill in the required fields for the new subscriber, including the account ID and list selection.
Map the user’s full name by combining first and last names. Enter the user’s email address from the FunnelKit response. Save the action and send the test request to ensure everything is working.
This setup ensures that every time a new user is added in FunnelKit, their details will automatically create or update a subscriber in AWeber through Pabbly Connect.
5. Testing the Integration Between FunnelKit and AWeber
After completing the setup, it’s crucial to test the integration. To do this, create a new user in FunnelKit using the registration form. Fill in the required fields and submit the form to trigger the automation.
Once submitted, return to Pabbly Connect to check if the webhook response has been received. If successful, the details of the new user will be displayed, confirming that the integration is functioning as intended.
Verify the user details in the Pabbly Connect response. Check AWeber to see if the new subscriber has been added. Repeat the test with different user data to ensure reliability.
This testing process confirms that your integration between FunnelKit and AWeber via Pabbly Connect is working seamlessly. You can now automate subscriber management efficiently.
In this tutorial, we demonstrated how to create AWeber subscribers from FunnelKit using Pabbly Connect. By following the steps outlined, you can automate your subscriber management process effectively. This integration saves time and ensures that your email list is always up-to-date with new user registrations.
