Learn how to integrate FunnelKit with AWeber using Pabbly Connect. This detailed tutorial guides you through creating subscribers automatically. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
Accessing Pabbly Connect for FunnelKit and AWeber Integration
To create AWeber subscribers from FunnelKit, the first step is to access Pabbly Connect. This powerful integration platform allows you to automate tasks seamlessly. Start by visiting the Pabbly Connect website and signing in or signing up for a free account if you don’t have one.
Once logged in, you will see the dashboard. Here, you can create workflows to connect FunnelKit with AWeber. Click on the ‘Access Now’ button under Pabbly Connect to navigate to the workflow creation area, where you can set up your automation process.
Now, it’s time to create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button and give your workflow a name, such as ‘Create AWeber Subscriber from FunnelKit User’. Select a folder to save your workflow, then click on ‘Create’ to proceed.
This opens the workflow setup window, where you will configure the trigger and action applications. The first step is to set FunnelKit as your trigger application. Select the trigger event as ‘New User’ to capture new user registrations automatically.
- Set FunnelKit as the trigger application.
After selecting the trigger event, connect FunnelKit to Pabbly Connect using the provided VB URL. This URL acts as a bridge between the two applications, enabling data transfer.
Setting Up Automation in FunnelKit
Next, navigate to your WordPress account where FunnelKit is installed. Go to the FunnelKit automations section and click on ‘Add New Automation’. Name your automation something relevant, like ‘AWeber Subscriber Automation’. Set the trigger as ‘User Created’ to initiate the process when a new user registers.
Once the trigger is set, add an action by selecting ‘Send Data to Pabbly Connect’. Here, you will paste the VB URL you copied earlier. This step is crucial as it ensures that the user data is sent to Pabbly Connect for processing.
- Select ‘User Created’ as the trigger in FunnelKit.
- Choose ‘Send Data to Pabbly Connect’ as the action.
- Paste the VB URL to connect the two platforms.
After setting this up, map the user data fields from FunnelKit to ensure that the correct information is sent to Pabbly Connect. This includes the username, first name, last name, and email address.
Creating AWeber Subscriber in Pabbly Connect
With the automation set up, return to Pabbly Connect to configure the action application. Select AWeber as your action app and choose ‘Add or Update Subscriber’ as the action event. This allows you to create a new subscriber in AWeber whenever a new user is added in FunnelKit.
Connect your AWeber account by entering your login credentials. Once connected, you will need to fill in the required details for the new subscriber, including the account ID and the list to which the subscriber will be added.
Select AWeber as the action application. Choose ‘Add or Update Subscriber’ as the action event. Map user details from FunnelKit to AWeber fields.
After mapping the fields, click on ‘Save and Send Test Request’ to verify that the integration works correctly. You should receive a positive response indicating that the subscriber has been successfully created.
Testing the Integration Between FunnelKit and AWeber
Finally, to ensure everything is functioning properly, test the integration by creating a new user in FunnelKit. Fill out the registration form with the necessary details and submit it. This action should trigger the automation you set up in Pabbly Connect.
After submitting the form, check your AWeber account to see if the new subscriber has been added. If successful, you will see the subscriber’s details reflected in AWeber, confirming that the integration between FunnelKit and AWeber via Pabbly Connect is working seamlessly.
Create a new user in FunnelKit. Check AWeber for the new subscriber entry. Ensure all details are correct and mapped properly.
By following these steps, you have successfully integrated FunnelKit with AWeber using Pabbly Connect. This automation will save time and ensure that your subscriber list is always up-to-date with new registrations.
In this tutorial, we explored how to create AWeber subscribers from FunnelKit using Pabbly Connect. By setting up triggers and actions, you can automate the subscriber creation process efficiently. This integration enhances your workflow and keeps your email list current.
