Learn how to create an AWeber subscriber on Typeform submission using Pabbly Connect. This step-by-step tutorial guides you through the integration process. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To create an AWeber subscriber on Typeform submission, you first need to access Pabbly Connect. This platform serves as the central hub for integrating various applications like Typeform and AWeber.
Visit the Pabbly Connect homepage by typing ‘Pabbly.com/connect’ in your browser. Here, you can either sign in if you are an existing user or click on the ‘Sign Up for Free’ button to create a new account. As a new user, you will receive 100 free tasks every month to explore the platform.
Once logged in to Pabbly Connect, navigate to the dashboard and click on the ‘Create Workflow’ option. This action initiates the setup for your automation process.
  • Provide a name for your workflow, such as ‘Create AWeber Subscriber on Typeform Submission.’
  • Select a folder for better organization, such as ‘Automations for Lead Management.’
  • Click ‘Create’ to finalize the setup.
After creating the workflow, you will see two main sections: Trigger and Action. The Trigger defines what starts the workflow, while the Action specifies what happens next. In this case, your trigger will be a new submission from Typeform.
3. Setting Up the Trigger for Typeform Submissions
To proceed, select Typeform as your trigger application in Pabbly Connect. You need to select the trigger event that will initiate the workflow. Choose ‘New Entry’ to capture responses from Typeform submissions.
Next, establish the connection between Typeform and Pabbly Connect. If you don’t have an existing connection, click on ‘Add New Connection’ and then ‘Connect with Typeform.’ You will be prompted to authorize Pabbly Connect to access your Typeform account. Once authorized, select the specific form you want to connect, such as your registration form, and click ‘Save and Send Test Request.’
4. Capturing Responses from Typeform
After submitting the test form, Pabbly Connect will capture the response. You should see all details, including the first name, last name, phone number, and email address submitted through Typeform. This confirms that the connection is successfully established.
Now, you can proceed to set up the action to create or update a subscriber in AWeber. This will be based on the captured response from your Typeform submission. Navigate to the action step and select AWeber as your action application.
  • Choose the action event as ‘Add or Update Subscriber.’
  • Connect to your AWeber account by adding a new connection.
  • Authorize Pabbly Connect to access your AWeber account.
After the connection is established, you will need to map the fields from the Typeform response to the AWeber fields, ensuring that each new lead is either added or updated accordingly.
Once you have mapped all necessary fields, click on ‘Save and Send Test Request’ in Pabbly Connect. This action will send the captured details to AWeber, creating or updating the subscriber based on the information submitted through Typeform.
To verify the integration, check your AWeber account under the subscribers section. You should see the newly created subscriber based on the test submission from Typeform. This confirms that every time a new form is submitted, the lead will automatically be added or updated as a subscriber in AWeber.
With this setup, you can efficiently manage your email marketing list, ensuring that all leads are captured and maintained without manual effort. Pabbly Connect enables seamless integration between Typeform and AWeber, streamlining your workflow.
In this tutorial, you learned how to create an AWeber subscriber on Typeform submission using Pabbly Connect. This integration automates the process of adding leads to your email marketing list, enhancing your lead management efficiency.
