Learn how to create AWeber subscribers automatically from Tally Forms submissions using Pabbly Connect. Follow this step-by-step guide for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To create AWeber subscribers from Tally Forms submissions, you need to access Pabbly Connect. Start by opening your web browser and navigating to the Pabbly Connect website.
If you don’t have an account, click on the ‘Sign Up for Free’ button. This will allow you to create an account in just a few minutes, enabling you to utilize 100 free tasks every month. If you already have an account, simply log in to access the dashboard.
Once you’re logged into Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button to initiate this process.
- Name your workflow, for example, ‘Create AWeber Subscriber on Tally Forms Submission’.
- Select the folder where you want to save your workflow.
- Click on ‘Create’ to proceed to the main workflow interface.
In this window, you’ll see two boxes labeled Trigger and Action. The Trigger box is where you will set up the event that starts the workflow. Action is what happens as a result of that trigger.
3. Setting Up the Trigger for Tally Forms
In the Trigger section, search for Tally Forms as your application. Select it, then choose the trigger event as ‘New Response’.
Next, you need to connect Tally Forms with Pabbly Connect using the provided VAB URL. This URL acts as a bridge between Tally Forms and Pabbly Connect. Copy the URL and head over to your Tally Forms account.
- Open your Tally Forms account and navigate to the form you want to connect.
- Go to the Integrations tab and select the option for Webhooks.
- Paste the copied VAB URL in the endpoint URL field and click ‘Connect’.
Now your Tally Forms are connected to Pabbly Connect, and it will wait for a new form submission response.
4. Setting Up the Action to Create AWeber Subscriber
After setting up your trigger, the next step is to configure the Action section. Search for AWeber as your action application and select it.
Choose the action event as ‘Add or Update Subscriber’. You will then need to connect your AWeber account with Pabbly Connect. Click on ‘Connect’, enter your AWeber login details, and allow access to complete the connection.
Select the Account ID and List ID where you want to add the subscriber. Map the fields from the Tally Forms submission to the AWeber subscriber fields. Click ‘Save and Send Test Request’ to finalize the setup.
This mapping ensures that every new form submission from Tally Forms automatically creates a new subscriber in your AWeber account with the correct details.
Now that you have set up both the trigger and action, it’s time to test the automation. Create a test submission in your Tally Forms by filling out the form with sample data.
Once the form is submitted, head back to Pabbly Connect to check if the response has been received. If successful, you should see the details of the new subscriber in your AWeber account.
Verify that the subscriber has been created with the correct details in AWeber. You can check the subscriber list in AWeber to confirm the entry.
This testing phase confirms that the integration is working seamlessly, allowing you to automate the process of adding new subscribers from Tally Forms to AWeber using Pabbly Connect.
In this tutorial, we explored how to create AWeber subscribers from Tally Forms submissions using Pabbly Connect. By following the steps outlined, you can automate your subscriber management efficiently. This integration saves time and ensures that no potential client is missed in your email marketing efforts.
