Learn how to create AWeber subscribers automatically from Tally Forms submissions using Pabbly Connect. Step-by-step tutorial with detailed instructions. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To create AWeber subscribers on Tally Forms submission, first, you need to access Pabbly Connect. This powerful tool facilitates the automation process seamlessly. Open your browser and navigate to the Pabbly Connect website.
If you don’t have an account, click on the ‘Sign Up for Free’ button to create one. Once signed up, you will receive 100 free tasks every month, which is perfect for testing your automation workflows.
After logging into Pabbly Connect, you need to create a new workflow. Click on the ‘Create Workflow’ button, which will prompt you to name your workflow. For this tutorial, name it ‘Create AWeber Subscriber on Tally Forms Submission’.
  • Select the folder where you want to save your workflow.
  • Click on ‘Create’ to proceed to the workflow setup.
In the workflow, you will see two sections: Trigger and Action. The Trigger section is where you define the event that starts the automation, while the Action section specifies what happens next.
3. Setting Up the Trigger with Tally Forms
In this step, you will configure the Trigger in Pabbly Connect. Search for Tally Forms in the Trigger application section. Select it and then choose the event ‘New Response’ as your trigger event.
Next, you will need to connect Tally Forms with Pabbly Connect. Copy the provided VAB URL from Pabbly Connect and navigate to your Tally Forms account. In Tally Forms, go to the Integrations section, select the Vook option, and paste the VAB URL into the endpoint URL field to establish the connection.
4. Creating AWeber Subscriber Action in Pabbly Connect
Now that the Trigger is set up, it’s time to configure the Action. Search for AWeber in the Action application section and select it. Choose the action event as ‘Add or Update Subscriber’. This will allow you to add new subscribers based on the form submissions.
Connect your AWeber account with Pabbly Connect by entering your login details and allowing access. After a successful connection, you will need to map the fields from the Tally Forms submission to AWeber. This includes mapping the subscriber’s full name, email address, and phone number.
  • Map the first name and last name from the Tally Forms submission to create the full name.
  • Ensure the email address and phone number fields are also mapped correctly.
Once all fields are mapped, click on ‘Save and Send Test Request’ to create a new subscriber in AWeber using the details from your Tally Forms submission.
5. Verifying the Subscriber Creation in AWeber
After successfully setting up the Action, it’s essential to verify that the subscriber has been created in AWeber. Go to your AWeber account and check the Subscribers section. You should see the new subscriber listed there, complete with the details you provided in the Tally Forms submission.
This integration using Pabbly Connect ensures that every time a new form submission is received, a new subscriber is automatically added to your AWeber list, streamlining your communication with potential clients.
With this setup, you can efficiently manage your leads and keep them updated with personalized emails, fitness tips, and special offers. This automation saves you time and enhances your business operations.
By following this tutorial, you’ve learned how to create AWeber subscribers automatically from Tally Forms submissions using Pabbly Connect. This integration enhances your ability to manage leads effectively and streamline your communication process.
