Learn how to integrate LinkedIn Leads with AWeber using Pabbly Connect. This detailed tutorial covers every step for seamless automation. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Accessing Pabbly Connect for LinkedIn Leads
To create an AWeber subscriber from LinkedIn leads, we will use Pabbly Connect. Start by visiting the Pabbly Connect homepage. If you’re a new user, click on ‘Sign Up Free’ to create an account and receive 300 tasks every month.
For existing users, simply click on ‘Sign In’. Once logged in, you will see the Pabbly Apps window where you can access various Pabbly applications. Click on Pabbly Connect to proceed with your integration setup.
In Pabbly Connect, you need to create a workflow to automate the process. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard. Name your workflow something like ‘Create AWeber Subscriber from LinkedIn Leads’ and select your preferred folder, such as ‘Automations’.
  • Click on the ‘Create’ button to establish the workflow.
  • You will see the trigger and action setup options.
Next, set up your trigger by selecting ‘LinkedIn Lead Gen Forms’ as the trigger application and ‘New Lead Gen Form Response’ as the trigger event. This setup will ensure that whenever a new lead is collected, it will initiate the workflow.
3. Connecting LinkedIn Leads to Pabbly Connect
To connect your LinkedIn Lead Gen Forms with Pabbly Connect, click on ‘Connect’ and then select ‘Add New Connection’. If you have previously connected your LinkedIn account, you can choose that existing connection instead.
After selecting ‘Connect with LinkedIn Lead Gen Forms’, you will be prompted to authorize the connection. Once authorized, select your account (e.g., Navin Ki) and the specific lead form you want to track (for example, a simple lead form). This connection allows Pabbly Connect to capture the latest leads.
4. Testing the LinkedIn Lead Trigger
Now that your trigger is set up, it’s time to test it. Go to your LinkedIn Lead Gen Form account and submit a new response. Fill in the required fields such as email and phone number. For demonstration, use an email like [email protected] and a random phone number.
  • Ensure that the first name, last name, and company name fields are filled automatically.
  • Click on ‘Submit’ to send the information to Pabbly Connect.
After submitting, return to Pabbly Connect and click on ‘Save and Send Test Request’. You should see a successful response with all the lead details captured, confirming that the trigger is working correctly.
5. Setting Up AWeber Action in Pabbly Connect
With the trigger successfully set, it’s time to set up the action step. Select ‘AWeber’ as your action application and ‘Add or Update Subscriber’ as the action event. Again, click on ‘Connect’ to establish a new connection with AWeber.
Once connected, select the list ID where you want to add the subscriber (like ‘New Customer’). Then, map the data from the LinkedIn lead to the AWeber fields. This includes mapping the full name, email, and phone number to their respective fields in AWeber.
Finally, click on ‘Save and Send Test Request’ to verify that the subscriber is added correctly. You can check your AWeber account to confirm that the new subscriber has been created with the details you provided. This completes your integration process using Pabbly Connect.
In this tutorial, we explored how to create an AWeber subscriber from LinkedIn leads using Pabbly Connect. By following these steps, you can automate the process of adding new leads as subscribers, enhancing your marketing efforts efficiently.
