Learn to integrate Facebook Lead Ads with AWeber using Pabbly Connect. This step-by-step tutorial covers all necessary actions and settings. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Signing in to Pabbly Connect for Integration
To create an AWeber subscriber from Facebook Lead Ads, you first need to access Pabbly Connect. Start by signing into your Pabbly account. If you do not have an account, you can sign up for free.
After signing in, you will be directed to the dashboard. Here, you can see all your workflows. Click on the option to create a new workflow, and name it appropriately, such as ‘Create AWeber Subscriber for Facebook Lead Ads’. This workflow will automate the entire process of capturing leads from Facebook.
In this section, we will set up the trigger that will start the workflow. The trigger is essential as it initiates the automation process whenever a new lead is generated from Facebook Lead Ads.
  • Select ‘Facebook Lead Ads’ as your trigger application.
  • Choose the trigger event, which is ‘New Lead’.
Once you have selected the trigger application and event, you will need to authenticate your Facebook account. This allows Pabbly Connect to access your Facebook Lead Ads and retrieve lead information automatically.
3. Configuring Facebook Lead Ads Integration
After setting up the trigger, you need to configure the Facebook Lead Ads settings. This step is crucial for ensuring that the correct leads are being captured.
  • Select the Facebook Page associated with your lead ads.
  • Choose the specific lead form you want to use.
Once you configure these settings, you can test the connection. Click on the ‘Test Request’ button to ensure that Pabbly Connect successfully retrieves data from your selected lead form. If the test is successful, you’ll see a confirmation message indicating that the lead data is ready to be processed.
4. Setting Up AWeber Integration in Pabbly Connect
The next step is to set up AWeber as the action application in your workflow. This allows you to create a subscriber in AWeber whenever a new lead is captured from Facebook Lead Ads.
Select AWeber as your action application and choose the action event as ‘Create Subscriber’. You will need to connect your AWeber account to Pabbly Connect by entering your login details.
After connecting, you will need to map the fields from the Facebook Lead Ads to AWeber. This involves selecting the corresponding fields such as first name, last name, and email address from the lead data to ensure accurate subscriber creation.
After configuring both the trigger and action, it is important to test the entire workflow. This ensures that leads from Facebook Lead Ads are correctly added as subscribers in AWeber.
Go back to your Facebook Lead Ads testing tool and submit a test lead. Check if the lead information appears in your Pabbly Connect workflow. If everything is set up correctly, you should see the new subscriber created in AWeber.
Once verified, you can finalize the workflow. Click on the ‘Save’ button in Pabbly Connect to activate the automation. This will ensure that every new lead from Facebook Lead Ads will automatically create a subscriber in AWeber without any manual intervention.
This tutorial demonstrated how to create an AWeber subscriber automatically from Facebook Lead Ads using Pabbly Connect. By following these steps, you can streamline your lead generation process efficiently.
