Learn how to integrate Graphy and Stripe payments seamlessly using Pabbly Connect in this detailed tutorial. Step-by-step instructions included. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To start integrating Graphy and Stripe, we need to access Pabbly Connect. This platform simplifies automation and integration processes, allowing seamless communication between applications.
Visit the Pabbly Connect homepage by typing ‘Pabbly.com/connect’ in your browser. Here, you can either sign in if you’re an existing user or click on the ‘Sign Up for Free’ button to create a new account. New users receive 100 free tasks each month to explore the platform.
Once logged into Pabbly Connect, we can create a new workflow to automate the enrollment process. Click on the ‘Create Workflow’ option and name it, such as ‘Create and Enroll User in Graphy for Stripe Payment’.
After naming your workflow, you can select a folder to save it. This organization helps in managing multiple workflows. Click on ‘Create’ to proceed, and you will see options for setting up triggers and actions. Set Stripe as the trigger application and Graphy as the action application.
Setting Up Stripe Trigger in Pabbly Connect
The next step involves configuring the trigger for Stripe in Pabbly Connect. Select Stripe as the trigger application and choose the event ‘Checkout Session Completed’. This event triggers the workflow whenever a payment is successfully processed.
After selecting the event, you will receive a webhook URL. This URL is crucial for connecting your Stripe account with Pabbly Connect. Follow these steps to set it up:
  • Navigate to the Developer section in your Stripe account.
  • Select the Webhooks option and click on ‘Add Endpoint’.
  • Paste the webhook URL from Pabbly Connect and select the event ‘Checkout Session Completed’.
After adding the endpoint, your Stripe account will successfully communicate with Pabbly Connect whenever a payment is made.
Filtering Payments in Pabbly Connect
To ensure that only relevant payments trigger the workflow, we will apply a filter in Pabbly Connect. This filter will check if the payment link corresponds to the specific course we are interested in, such as the PHP course.
Set the filter to check if the payment link from the Stripe response equals the predefined link for the PHP course. This ensures that only payments made for this specific course will continue the workflow. If the condition is met, the workflow will proceed to the next action; otherwise, it will stop.
Enrolling the Learner in Graphy
After the filter step, the next action in Pabbly Connect involves enrolling the learner in Graphy. Select Graphy as the action application and choose the ‘Create Learner’ event. Connect your Graphy account by entering the required API key and Merchant ID, which can be found in the integration settings of your Graphy account.
Map the details received from Stripe, such as email and name, to the corresponding fields in Graphy. This ensures that the learner’s information is accurately captured when they make a payment. Finally, save the configuration and send a test request to confirm that the learner is created successfully in Graphy.
Next, you’ll want to enroll the learner in the PHP course by selecting the ‘Enroll Learner to Course’ action and mapping the learner’s email along with the course URL. Once again, send a test request to ensure everything is functioning as expected.
By following these steps using Pabbly Connect, you can automate the process of creating and enrolling learners in Graphy whenever a payment is made through Stripe. This integration not only saves time but also enhances the user experience by ensuring seamless enrollment in courses.
