Learn how to set up ActiveCampaign contacts from Typebot using Pabbly Connect. Follow this step-by-step guide for seamless integration. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Setting Up Pabbly Connect for Typebot Integration
To automate the process of creating ActiveCampaign contacts from Typebot interactions, you will use Pabbly Connect. First, sign up for a free account on Pabbly Connect. Once you have your account, log in to access the dashboard.
Next, create a new workflow. Click on the ‘Create Workflow’ button and name your workflow, for example, ‘Typebot to ActiveCampaign’. Select a folder for the workflow and click on ‘Create’. This action sets the stage for the integration process.
2. Creating the Trigger in Pabbly Connect
The next step is to set up a trigger in Pabbly Connect. In the workflow, you will see two windows: the trigger window and the action window. Start by selecting Typebot as the app in the trigger window.
  • Search for ‘Typebot’ in the app list.
  • Select the trigger event as ‘P Block Triggered’.
This webhook URL needs to be added to the Typebot flow you created. Go to your Typebot flow and add a new block for integration, pasting the webhook URL into the configuration.
3. Testing the Trigger with Typebot
After configuring the webhook in Typebot, it’s crucial to test the trigger. In Pabbly Connect, you can click on the ‘Test Request’ button to receive a dummy response. This confirms that the connection is working.
Once you receive the test response, you can proceed to capture actual responses. Go back to Typebot and complete the conversation flow by entering user details such as name, email, and phone number. This interaction will send real data back to Pabbly Connect.
4. Setting Up ActiveCampaign Action in Pabbly Connect
With the trigger now set, the next step is to configure the action to create a contact in ActiveCampaign using Pabbly Connect. In the action window, search for ActiveCampaign and select it.
  • Choose the action event ‘Create or Update Contact’.
  • Connect your ActiveCampaign account by entering the API key and URL.
  • Ensure to remove the protocol from the URL before saving.
After the connection is established, map the user details received from Typebot into the respective fields in ActiveCampaign, such as email, first name, last name, and additional information.
5. Final Testing and Verification of Automation
Once you have mapped all necessary fields, it’s time to test the entire workflow. In Pabbly Connect, click on ‘Save and Send Test Request’ to verify that the contact is created in ActiveCampaign as expected.
Check your ActiveCampaign account to confirm that the new contact appears with the details you entered in Typebot. If everything is set up correctly, you should see the contact listed with all the provided information.
By following this detailed guide, you can successfully integrate Typebot with ActiveCampaign using Pabbly Connect. This automation streamlines the process of adding contacts based on user interactions, enhancing your workflow efficiency.
