Learn how to automate subscriber creation in MailerLite from WooCommerce orders using Pabbly Connect. Step-by-step tutorial with detailed instructions. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Introduction to Pabbly Connect for WooCommerce and MailerLite Integration
Pabbly Connect is an excellent tool for automating workflows between different applications. In this tutorial, we will use Pabbly Connect to create a subscriber in MailerLite when a new order is placed in WooCommerce. This integration allows you to streamline your email marketing efforts by automatically adding customers to your mailing list.
Using Pabbly Connect, you can eliminate manual data entry and ensure that every new customer is added to your MailerLite group. This automation helps in targeting customers effectively with tailored email campaigns based on their order history.
2. Setting Up Pabbly Connect for WooCommerce
To begin, you need to access Pabbly Connect. Open a new tab in your browser and search for Pabbly Connect. If you don’t have an account, click on the ‘Sign up for free’ button to create one. After signing in, navigate to the Pabbly Connect dashboard.
Once you’re in the dashboard, create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow ‘Create Subscriber in MailerLite Group on WooCommerce Order’ and select the appropriate folder for organization. This setup will allow you to connect WooCommerce and MailerLite seamlessly.
3. Setting Up the Trigger for New Orders in WooCommerce
In this step, we will set up the trigger in Pabbly Connect. Click on the trigger application and search for WooCommerce. Select WooCommerce and choose the trigger event as ‘New Order Created.’ This event will initiate the workflow whenever a new order is placed.
Next, you will need to connect WooCommerce with Pabbly Connect. Copy the webhook URL provided and head over to your WooCommerce settings in your WordPress account. Under the ‘Advanced’ settings, find the ‘Webhooks’ option and click on ‘Add Webhook.’ Fill in the details such as name, status, and topic, and paste the webhook URL you copied earlier.
  • Name: MailerLite
  • Status: Active
  • Topic: Order Created
After saving the webhook, return to Pabbly Connect. Click on ‘Re-capture Webhook Response’ to confirm that the connection is successful. You will see a confirmation message once the webhook is correctly set up.
4. Setting Up the Action to Create a Subscriber in MailerLite
Now, we will set up the action in Pabbly Connect to create a subscriber in MailerLite. Search for MailerLite in the action application section and select it. Choose the action event as ‘Create or Update Subscriber.’ This action will create a new subscriber based on the order details received from WooCommerce.
To connect MailerLite with Pabbly Connect, you will need an API token. Log in to your MailerLite account, navigate to the Integrations section, and generate a new API token. Copy this token and paste it back into Pabbly Connect to establish the connection.
  • Subscriber Email: Map this from the WooCommerce order response.
  • Status: Set to Active.
  • Group: Select the WooCommerce group from MailerLite.
After mapping the necessary fields, click on ‘Save and Send Test’ to verify that the subscriber is created successfully. You should receive a positive response indicating that the subscriber has been added to MailerLite.
5. Conclusion: Successfully Automating Subscriber Creation with Pabbly Connect
In this tutorial, we successfully integrated WooCommerce with MailerLite using Pabbly Connect. By following these steps, you can automate the process of adding new customers as subscribers in MailerLite, enhancing your email marketing strategy.
This integration not only saves time but also helps in maintaining an organized and segmented list of subscribers based on their purchase behavior. With Pabbly Connect, you can ensure a seamless connection between your WooCommerce store and your MailerLite account for effective marketing campaigns.
