Learn how to integrate Razorpay and beehiiv using Pabbly Connect to automate subscriber creation upon payment. Step-by-step guide included. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Creating a Payment Page in Razorpay
In this section, we’ll discuss how to create a payment page in Razorpay using Pabbly Connect. Start by logging into your Razorpay account and navigating to the payment pages section in the left sidebar.
Here, you will create a payment page where customers can enter their payment details. Ensure you include essential fields such as name, email, and product details. After creating the page, save it and copy the link to use later.
2. Setting Up Pabbly Connect for Integration
Once your payment page is ready, the next step is to set up Pabbly Connect to automate the subscriber creation in beehiiv. Begin by logging into your Pabbly Connect dashboard and creating a new workflow.
In the workflow, you will set Razorpay as the trigger app. Select the event as payment captured. This will allow Pabbly Connect to listen for new payments made through your Razorpay payment page.
  • Log into your Pabbly Connect account.
  • Create a new workflow and name it.
  • Select Razorpay as the trigger app.
  • Choose the trigger event as payment captured.
After setting up the trigger, Pabbly Connect will provide a webhook URL. This URL needs to be added to your Razorpay account to connect the two platforms.
3. Connecting Razorpay Webhook to Pabbly Connect
To complete the integration, you need to add the webhook URL provided by Pabbly Connect to your Razorpay account. Go to your Razorpay dashboard, navigate to account settings, and find the webhooks section.
Click on ‘Add New Webhook’, paste the webhook URL, and set the active event to payment captured. This setup ensures that whenever a payment is made, Razorpay sends the payment details to Pabbly Connect.
  • Navigate to Razorpay account settings.
  • Select ‘Add New Webhook’.
  • Paste the Pabbly Connect webhook URL.
  • Set the event to payment captured.
Once the webhook is set up, Pabbly Connect will be ready to receive payment data from Razorpay.
4. Creating a Subscriber in beehiiv
Now that Razorpay is connected to Pabbly Connect, the next step is to create a subscriber in beehiiv. In your Pabbly Connect workflow, add an action step to select beehiiv as the application.
Choose the action event as create subscriber. You will need to connect your beehiiv account by providing the API token from your beehiiv settings. Once connected, map the required fields such as email and subscriber name from the Razorpay payment data.
Add an action step in Pabbly Connect for beehiiv. Select create subscriber as the action event. Provide your beehiiv API token. Map the email and name fields from Razorpay data.
After mapping the fields, test the action to ensure that the subscriber is created successfully in beehiiv whenever a payment is received.
5. Testing the Integration
Finally, it’s time to test the integration. Make a test payment on your Razorpay payment page. Once the payment is processed, Pabbly Connect should capture the payment details and create a new subscriber in your beehiiv account.
Check your beehiiv subscribers list to confirm that the new subscriber is added with the correct details. This testing phase ensures that your automation is functioning as intended.
If everything works correctly, you can now automate the process of adding subscribers in beehiiv based on Razorpay payments, saving you time and effort.
This tutorial has guided you through integrating Razorpay with beehiiv using Pabbly Connect. By automating subscriber creation, you can streamline your processes and enhance your customer management. Try implementing this automation today for a more efficient workflow.
