Learn how to connect RSS Feed with Instagram using Pabbly Connect in this detailed tutorial. Step-by-step guide for seamless integration. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To connect RSS Feed with Instagram, you first need to access Pabbly Connect. Start by signing into your Pabbly Connect account. If you’re a new user, click on the ‘Sign Up for Free’ button to create an account and receive 100 free tasks monthly.
Once logged in, navigate to the applications page and select Pabbly Connect. Click on ‘Access Now’ to reach your dashboard, where you can create your automation workflow.
To create a new workflow in Pabbly Connect, locate the ‘Create Workflow’ button on the right-hand side of your dashboard. Click it to open a dialog box where you can name your workflow, such as ‘Connect RSS Feed with Instagram’.
  • Organize it into a folder, like ‘RSS Feed to Instagram’.
  • Click ‘Create’ to finalize your workflow setup.
After creating the workflow, you will arrive at a new window where you can set up your trigger and action applications. This is the core of your integration process using Pabbly Connect.
3. Setting Up the Trigger for RSS Feed
In this step, you will set up the trigger application in Pabbly Connect. Select ‘RSS by Pabbly’ as your trigger application and choose ‘New Item in Feed’ as the trigger event. This trigger will activate whenever a new item is added to your RSS feed.
Next, you need to connect your RSS feed by entering the Feed URL. This URL is crucial as Pabbly Connect will check for updates at regular intervals, typically every 6 hours. Click on ‘Connect’ to establish this connection.
4. Configuring the Action to Post on Instagram
After setting up the trigger, you need to configure the action application in Pabbly Connect. Select ‘Instagram for Business’ as your action application and set the action event to ‘Publish Photo’. This will allow you to create a post on your Instagram account when a new RSS item is detected.
To connect your Instagram account, click on ‘Connect’ and authorize Pabbly Connect to access your Instagram for Business account. Once the connection is successful, you will proceed to map the details from your RSS feed response to the Instagram post fields.
  • Map the photo URL from the RSS feed response to the photo URL field.
  • Map the caption to the title of the RSS feed item.
This mapping ensures that each new post on Instagram reflects the most recent updates from your RSS feed, maintaining dynamic content.
With the trigger and action set up, it’s time to test the integration in Pabbly Connect. Click on ‘Save and Send Test Request’ to initiate the test. If configured correctly, you should receive a positive response indicating that the data has been successfully passed from the RSS feed to Instagram.
Check your Instagram account to confirm that a new post has been created with the image and caption from the RSS feed. This confirms that your automation is functioning as intended, allowing you to seamlessly connect RSS Feed with Instagram.
In this tutorial, we explored how to connect RSS Feed with Instagram using Pabbly Connect. By following these steps, you can automate your social media posts effortlessly, ensuring that your audience stays updated with the latest content from your RSS feed.
