Learn how to create a Telegram bot for generating AI images using Pabbly Connect. Step-by-step guide to integrate OpenAI and Telegram effortlessly. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Creating a Telegram Bot with Pabbly Connect
To start building a Telegram bot that generates AI images, you will first need to create the bot itself. This process is facilitated through Pabbly Connect, which allows seamless integration with various applications. Begin by accessing the Telegram app and searching for the BotFather.
After initiating a chat with BotFather, enter the command /newbot. You will then be prompted to provide a name for your bot. For example, you could name it ‘AI Image Gen’. After naming, create a unique username by appending ‘_bot’ to your chosen name, such as ‘AIImageGen_121’. Once completed, BotFather will provide an API token, which will be essential for connecting your bot to Pabbly Connect.
2. Setting Up Pabbly Connect for Automation
Next, you will set up Pabbly Connect to facilitate the automation of your Telegram bot. First, sign up for a free account on Pabbly Connect. After logging in, navigate to your dashboard and click on the Create Workflow button.
  • Name your workflow, for example, ‘Telegram AI Image Gen Bot’.
  • Select the appropriate folder for your workflow.
  • Click on the Create button.
Once the workflow is created, you will see two windows: the trigger and action windows. Here, you will set the trigger to receive messages from your Telegram bot, which will initiate the automation process.
3. Connecting Your Telegram Bot to Pabbly Connect
In the trigger window, search for the Telegram Bot app and select it. Choose the trigger event as Set Webhook. Click on Connect and then Add New Connection. You will need to paste the API token obtained from BotFather.
After pasting the token, click on Save. This action connects your Telegram bot to Pabbly Connect. To test the connection, click on the Save and Send Test Request button. The system will wait for a new message to be sent to your bot.
4. Generating AI Images Using OpenAI
Now that your Telegram bot is connected, the next step is to send the received message as a prompt to OpenAI for image generation. In the action window, search for OpenAI and select it. Choose the action event as Generate Image and click on Connect.
To connect OpenAI, you will need to enter your OpenAI API key, which can be obtained from your OpenAI account dashboard. Once connected, select the model you wish to use for image generation, such as DALL-E 2 or DALL-E 3. Map the prompt from the trigger step to the OpenAI action step.
  • Set the prompt to the message received from Telegram.
  • Specify the number of images to generate.
  • Select the desired image size and quality.
After configuring these settings, click on Save and Send Test Request to generate the image based on the prompt.
5. Sending the Generated Image Back to Telegram
After generating the image, the final step is to send this image back to the Telegram bot. In the action window, search for the Telegram bot again and select the action event as Send Photo. Connect using the existing connection established earlier.
In this step, you will need to map the chat ID from the trigger step to send the image back to the right user. Additionally, map the image URL generated from OpenAI as the photo to be sent. Finally, add a caption if desired, using the revised prompt from OpenAI.
Click on Save and Send Test Request to complete the process. You should see the generated image appear in your Telegram chat, confirming that the automation created with Pabbly Connect is working successfully.
This tutorial provided a clear guide on how to build a Telegram bot to generate AI images using Pabbly Connect. By following the steps outlined, you can create an efficient workflow that integrates Telegram with OpenAI, allowing for seamless image generation based on user prompts. Start using Pabbly Connect today to automate your processes effortlessly!
