Learn how to automatically publish WordPress posts on LinkedIn using Pabbly Connect. Follow our step-by-step tutorial to streamline your posting process. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To automatically publish WordPress posts on LinkedIn, the first step is to access Pabbly Connect. You can do this by visiting the Pabbly Connect website and signing in to your account. If you are a new user, you can sign up for free and get 100 tasks every month.
Once logged in, you will see the dashboard of Pabbly Connect. This dashboard allows you to create workflows that automate tasks between applications. To start, click on the ‘Create Workflow’ button located in the top right corner of the dashboard.
After clicking ‘Create Workflow’, you will be prompted to name your workflow. Name it as ‘Automatically Publish WordPress Post on LinkedIn’. Next, select a folder to save your workflow. Choose the folder named ‘LinkedIn Automations’ from the drop-down menu. using Pabbly Connect
- Click on the drop-down arrow next to the folder selection.
- Select the appropriate folder for your workflow.
- Click on ‘Create’ to finalize the workflow setup.
Now, you will see two sections: Trigger and Action. The trigger indicates when the automation will start, while the action defines what will happen as a result. In this case, we will set WordPress as the trigger application.
To set up the trigger, click on the arrow in the Trigger section and select ‘WordPress’ as the trigger application. For the trigger event, choose ‘New Post Published’. This means that every time a new post is published on your WordPress account, Pabbly Connect will capture this event.
Next, Pabbly Connect will provide you with a unique webhook URL. Copy this URL as you will need it to connect your WordPress account to Pabbly Connect. Now, open your WordPress account and navigate to the Plugins section.
- Select ‘Add New’ under the Plugins section.
- Search for the ‘WP Webhooks’ plugin and install it.
- Once installed, go to the WP Webhooks settings panel.
In the settings, click on ‘Send Data’ and select ‘Post Created’. Here, you will add the webhook URL that you copied from Pabbly Connect. This connects your WordPress account to the automation workflow you created.
4. Testing the Automation Setup
After setting up the webhook in WordPress, you need to test the automation. Go back to your Pabbly Connect workflow and ensure it is waiting for a webhook response. Now, create a dummy post in your WordPress account to trigger the automation.
Once you publish the dummy post, Pabbly Connect will capture the response. Check the workflow to see if the post details, including the title and content, are displayed correctly. This confirms that your WordPress account is successfully connected to Pabbly Connect.
Ensure the post is published and visible on your WordPress account. Check if the response in Pabbly Connect includes the correct post details.
If the response is captured successfully, you can move on to the next step of removing any HTML tags from the content using Pabbly Connect’s Data Transformer feature.
5. Finalizing the Post on LinkedIn
In this step, you will set up the action in Pabbly Connect to share the post on LinkedIn. Click on the plus button in the Action section and select ‘LinkedIn’ as the action application. For the action event, choose ‘Share an Article or URL’.
After connecting LinkedIn to Pabbly Connect, you will specify the author and content for the LinkedIn post. Map the content you received from the previous steps to ensure the correct post is shared. Also, include the article URL from your WordPress post.
Select the author for the LinkedIn post. Map the content without HTML tags to the content field. Set visibility to Pabbly for the post.
Finally, click on ‘Save and Send Test Request’ to share the post on LinkedIn. Check your LinkedIn account to confirm that the post appears correctly with the expected content and link.
In this tutorial, we demonstrated how to use Pabbly Connect to automatically publish WordPress posts on LinkedIn. By following the steps outlined, you can streamline your posting process and enhance your social media presence effortlessly.
