Learn how to automate posting Shopify blogs to Facebook groups using Pabbly Connect in this step-by-step tutorial. Discover the integration process now! Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start automating the process of posting Shopify blogs to Facebook groups, you first need to access Pabbly Connect. Simply open your web browser and visit the Pabbly Connect website. If you are a new user, click on the ‘Sign Up for Free’ button to create an account, which only takes a few minutes and includes 100 free tasks to explore the software.
Once you have created your account, log in by clicking on the ‘Sign In’ button. After logging in, you will be directed to the Pabbly Connect dashboard where you can manage your workflows. Click on the ‘Access Now’ button under Pabbly Connect to begin the integration process.
After accessing Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button located in the top right corner of the dashboard. A dialog will appear where you need to enter a name for your workflow, such as ‘Share Shopify Blog on Facebook Groups Automatically’. using Pabbly Connect
- Enter a unique name for your workflow.
- Select the folder where you want to save this workflow.
Once you have named and saved your workflow, you will see two windows: one for the trigger application and another for the action application. For this automation, select Shopify as the trigger application and Facebook as the action application.
3. Setting Up Shopify as the Trigger in Pabbly Connect
To set Shopify as the trigger, select it from the application list in Pabbly Connect. Then, choose the trigger event as ‘New Blog Entry’. This means that every time a new blog is created in your Shopify store, Pabbly Connect will capture that event. using Pabbly Connect
Click on the ‘Connect’ button to establish a connection with your Shopify account. You will need to provide the Admin API Access Token and your Shopify store’s subdomain. To find your subdomain, look at your Shopify store URL, which will be formatted as ‘yourstore.myshopify.com’. Copy the part before ‘.myshopify.com’ and paste it into Pabbly Connect.
- Create an app in Shopify to generate the API Access Token.
- Set permissions for the app to manage and read content.
After entering the necessary details, click on ‘Save’ to connect your Shopify account to Pabbly Connect. This will allow Pabbly Connect to retrieve blog details whenever a new blog is posted.
4. Setting Up Facebook as the Action in Pabbly Connect
Next, you need to set Facebook as the action application in Pabbly Connect. Select Facebook Groups and choose the action event as ‘Post Message’. This action will enable Pabbly Connect to post the blog content to your specified Facebook group. using Pabbly Connect
Click on the ‘Connect’ button to establish a connection with your Facebook account. Ensure you are logged into your Facebook account to simplify the connection process. Once connected, select the Facebook group where you want to post the blog. For instance, you might choose a group named ‘Social Circle’.
Select the group from the dropdown menu. Map the message field to include the blog content from Shopify.
After mapping the message field, click on ‘Save’ and send a test request to verify that the integration works. You should see a confirmation that the message has been posted to your Facebook group.
5. Conclusion: Automating Your Blog Posts
By following the steps outlined above, you can successfully automate the process of posting new Shopify blogs to Facebook groups using Pabbly Connect. This integration not only saves time but also ensures your audience is always updated with the latest content from your Shopify store.
Utilizing Pabbly Connect for this integration allows you to streamline your marketing efforts and maintain engagement with your community effortlessly. Now, whenever a new blog post is created in Shopify, it will be automatically shared in your chosen Facebook group, enhancing your online presence.
