Learn how to automatically add IndiaMART leads to Mailchimp using Pabbly Connect. Follow this step-by-step tutorial to streamline your lead management process. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect for IndiaMART and Mailchimp Integration
To automatically add IndiaMART leads to Mailchimp, you will first need to access Pabbly Connect. This platform allows you to create automated workflows between different applications seamlessly. Start by visiting the Pabbly Connect homepage and either sign in or sign up for a new account.
Once logged in, you will see the dashboard where you can create a new workflow. Pabbly Connect offers a user-friendly interface that simplifies the integration process. Here’s how to get started:
- Visit the Pabbly Connect homepage.
- Click on ‘Sign Up Free’ or ‘Sign In’ if you are an existing user.
- Navigate to the dashboard to create a new workflow.
After creating your account, you’re ready to set up your workflow for adding IndiaMART leads to Mailchimp.
In this step, you will create a workflow to automate the process of adding leads from IndiaMART to Mailchimp using Pabbly Connect. Click on the ‘Create Workflow’ button in the top right corner of the dashboard. Name your workflow appropriately, such as ‘IndiaMART Automation’ and select a folder for organization.
Next, you will set up the trigger and action for your workflow. The trigger will be IndiaMART, and the action will be Mailchimp. This means that every time a new lead is received in IndiaMART, it will automatically add that lead as a subscriber in Mailchimp.
- Click on ‘Create Workflow’.
- Set the trigger application to IndiaMART.
- Set the action application to Mailchimp.
With your workflow created, you can now connect IndiaMART to Pabbly Connect and specify the trigger event.
3. Connecting IndiaMART to Pabbly Connect
To connect IndiaMART to Pabbly Connect, you will need to set the trigger event as ‘New Leads’. Click on the connection option and select ‘Add New Connection’. You will be prompted to enter your CRM API key from your IndiaMART account.
To find your CRM API key, log into your IndiaMART account, navigate to settings, and then account settings. Here, you can generate a new key if needed. Copy the key and paste it into Pabbly Connect. After saving the connection, initiate a test request to ensure that the connection is successful.
Log into IndiaMART and navigate to account settings. Generate or copy your CRM API key. Paste the key into Pabbly Connect and save the connection.
Once the test request is successful, you can proceed to set up the action step for Mailchimp.
4. Configuring Mailchimp Integration in Pabbly Connect
Next, you will configure Mailchimp as the action application in Pabbly Connect. Select Mailchimp and choose the action event as ‘Add New Member with Custom Fields’. Click on the connection option again to connect your Mailchimp account.
To connect Mailchimp, you will need an API key and data center information. Generate a new API key in your Mailchimp account under your profile settings. Once you have the key, paste it into Pabbly Connect and enter the data center as indicated in your Mailchimp URL.
Select Mailchimp as the action application. Generate your Mailchimp API key. Enter the data center from your Mailchimp URL into Pabbly Connect.
After saving the connection, you will set up the fields for the new subscriber, including email address, first name, and last name, mapping the data from the previous steps.
After configuring both IndiaMART and Mailchimp in Pabbly Connect, it’s time to test the integration. Click on ‘Save and Send Test Request’ to verify that the lead information is correctly sent to Mailchimp. Check your Mailchimp account to see if the new contact has been added successfully.
In your Mailchimp account, navigate to the contacts section to verify that the newly added lead appears with the correct details. This confirms that the automation is working as intended. If there are any issues, you can revisit the workflow in Pabbly Connect and make necessary adjustments.
Click ‘Save and Send Test Request’ in Pabbly Connect. Check Mailchimp for the new contact. Adjust the workflow if necessary.
With the integration successfully tested, you are now set to automate the process of adding IndiaMART leads to Mailchimp using Pabbly Connect.
In this tutorial, we explored how to automate the addition of IndiaMART leads to Mailchimp using Pabbly Connect. By following the steps outlined, you can streamline your lead management process and enhance your marketing efforts. This integration allows for efficient handling of leads, ensuring that no potential customer is overlooked.
