Learn how to integrate WooCommerce with Slack for real-time order notifications using Pabbly Connect. Follow our step-by-step tutorial to streamline your e-commerce operations. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
1. Accessing Pabbly Connect for WooCommerce and Slack Integration
To start automating WooCommerce order notifications to Slack, you first need to access Pabbly Connect. This platform enables seamless integration between different applications without any coding knowledge. Simply visit the Pabbly Connect website and log in to your account.
Once logged in, you will see the Pabbly Connect dashboard. Here, you can create a new workflow that connects WooCommerce with Slack. Click on the ‘Create Workflow’ button to begin setting up your automation.
After clicking on ‘Create Workflow’, you will be prompted to name your workflow. For this integration, name it ‘Send WooCommerce Order Notifications to Slack Automatically’. This name will help you identify the workflow later on. using Pabbly Connect
  • Click on ‘Create’ to set up the workflow.
  • Select WooCommerce as the trigger application.
  • Choose the trigger event as ‘New Order Created’.
This setup ensures that every time a new order is placed in WooCommerce, Pabbly Connect will trigger the workflow and send the order details to Slack. You will receive a webhook URL that you will need to use in your WooCommerce settings.
3. Configuring WooCommerce Webhook for Pabbly Connect
To connect WooCommerce with Pabbly Connect, log into your WordPress admin panel. Navigate to WooCommerce settings and find the ‘Advanced’ tab. Within this tab, you will see the option for webhooks.
  • Click on ‘Add Webhook’ to create a new webhook.
  • Name the webhook (e.g., ‘Order Notifications’).
  • Set the status to ‘Active’ and select the topic as ‘Order Created’.
  • Paste the webhook URL from Pabbly Connect into the Delivery URL field.
After configuring the webhook, save the settings. This ensures that whenever a new order is created, WooCommerce will send the order data to your Pabbly Connect workflow.
4. Setting Up Slack Notifications through Pabbly Connect
Now that WooCommerce is connected to Pabbly Connect, the next step is to set up Slack as the action application. In your Pabbly Connect workflow, search for Slack and choose it as the action application.
Select ‘Send Channel Message’ as the action event. Connect your Slack account by providing the necessary permissions. Choose the channel where you want to send notifications (e.g., WooCommerce Orders).
During this setup, you will map the order details from the previous response to create a dynamic message. This means that each time a new order is received, the message will include the customer’s name, email, products ordered, and shipping address.
5. Testing the Integration of WooCommerce and Slack
After setting up the workflow, it’s time to test the integration. Place a test order in your WooCommerce store to see if the notification is sent to Slack. Once the order is placed, Pabbly Connect will capture the order details and send them to the specified Slack channel. using Pabbly Connect
Check your Slack channel to confirm that you received the notification with all the order details. If everything is set up correctly, you should see a message indicating that a new order has been received, along with the relevant details.
This automation streamlines your workflow and ensures that your team is promptly notified about new orders, enhancing operational efficiency.
Integrating WooCommerce with Slack using Pabbly Connect allows you to automate order notifications seamlessly. This ensures that your team stays informed and can respond quickly to new orders, improving your overall e-commerce operations.
