Learn how to automate LinkedIn posts using Pabbly Connect and Google Gemini. This tutorial covers step-by-step integration for efficient posting. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Pabbly Connect to Automate LinkedIn Posts
To automate LinkedIn posts using Pabbly Connect, the first step is to access the platform. Open your browser and search for Pabbly Connect. You will see options to sign in or sign up for a free account. If you don’t have an account, click on the ‘Sign Up for Free’ button, which takes only a few minutes and gives you 100 tasks free each month.
Once logged in, you will be directed to the Pabbly Connect dashboard. Here, click on the ‘Create Workflow’ button. You will be prompted to name your workflow; in this case, name it ‘Create LinkedIn Posts Using Google Gemini’. Select a folder to save your workflow and click ‘Create’. This sets the foundation for your automation.
2. Configuring Google Sheets as the Trigger in Pabbly Connect
The next step involves setting up Google Sheets as the trigger application in Pabbly Connect. In the workflow, you will see two boxes labeled ‘Trigger’ and ‘Action’. Start by selecting Google Sheets as your trigger application. In the trigger event options, choose ‘New or Updated Spreadsheet Row’. This event will initiate the workflow whenever a new row is added or updated in your Google Sheet.
  • Connect your Google Sheets with Pabbly Connect using the provided webhook URL.
After selecting your trigger, you need to connect Google Sheets with Pabbly Connect. Copy the webhook URL provided and go to your Google Sheets. Under the Extensions menu, look for the Pabbly Connect Webhooks option to set it up. This integration allows Pabbly Connect to receive data from your Google Sheets whenever a new post title and image URL are added.
3. Generating Post Descriptions Using Google Gemini
After setting up the trigger, the next step in Pabbly Connect is to generate content using Google Gemini. Add a new action step and select Google Gemini as the action application. Choose ‘Generate Content’ as the action event. Here, you will need to connect Google Gemini with Pabbly Connect using an API key.
To obtain the API key, log into your Google Gemini account and navigate to the Google AI Studio. Click on ‘Get API Key’ and create a new API key for your project. Copy this key and paste it into Pabbly Connect to establish the connection. Once connected, you can create a prompt for Google Gemini to generate a description for your LinkedIn post.
  • Select Google Gemini as the action application.
  • Set the action event to ‘Generate Content’.
  • Map the post title from Google Sheets into the content prompt for Google Gemini.
In the prompt, specify that the AI should create a unique and engaging description based on the title provided. This will ensure that your LinkedIn posts are not only automated but also relevant and tailored to your brand’s voice.
4. Creating the LinkedIn Post with Pabbly Connect
Once the content is generated, the final step is to create the post on LinkedIn using Pabbly Connect. Add another action step and select LinkedIn as the action application. Choose ‘Share Text with Image’ as the action event. Connect your LinkedIn account to Pabbly Connect by logging in and granting the necessary permissions.
In this step, map the generated content and the image URL from the previous steps into the LinkedIn post fields. Ensure that the post visibility is set to Pabbly so that it reaches your audience. After mapping all the required fields, click on ‘Save and Send Test’. This will create the post on your LinkedIn account automatically.
Select LinkedIn as the action application. Choose ‘Share Text with Image’ as the action event. Map the required fields including post title, description, and image URL.
After successfully testing the action, you will see the new post appear on your LinkedIn account, confirming that the automation works seamlessly. This integration allows you to maintain a consistent posting schedule without manual intervention.
5. Conclusion: Streamlining LinkedIn Posting with Pabbly Connect
In conclusion, using Pabbly Connect to automate LinkedIn posts with Google Gemini significantly enhances efficiency. By setting up triggers in Google Sheets and generating content through Google Gemini, you can ensure that your LinkedIn presence remains active and engaging.
This integration not only saves time but also allows for consistent branding and messaging. With Pabbly Connect, you can focus on your business while automating your social media efforts effectively.
