Learn how to automate posting The Hindu RSS feed on Telegram using Pabbly Connect. Follow our step-by-step guide for seamless integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Introduction to Pabbly Connect for RSS Feeds
In this tutorial, we will explore how to use Pabbly Connect to automate posting The Hindu RSS feed on Telegram. Automation saves time and ensures timely updates for your subscribers. By integrating RSS feeds with Telegram, you can share breaking news automatically.
To begin, you need to access Pabbly Connect. If you don’t have an account, you can sign up for free and get 100 tasks every month. Once signed in, you will be directed to the dashboard where you can start creating workflows.
To create a workflow in Pabbly Connect, click on the ‘Create Workflow’ button located at the top right corner of the dashboard. A dialog box will appear asking for a workflow name.
For this automation, name your workflow ‘How to Auto Post The Hindu RSS Feed on Telegram’ and select a folder to save it in. Here are the steps to follow:
- Click on ‘Create Workflow’
- Enter the workflow name
- Choose a folder for your workflow
After completing these steps, click on ‘Create’ to initiate your workflow. You will see two main sections: Trigger and Action. The Trigger section will determine when the automation starts, while the Action section will define what happens next.
In the Trigger section of Pabbly Connect, select ‘RSS by P’ as your application. For the Trigger Event, choose ‘New Item in Feed’. This setup will ensure that whenever a new item is published in The Hindu RSS feed, it will trigger the automation.
Next, you will need to provide the RSS feed URL. Here’s how to do it:
- Open The Hindu RSS feed page
- Copy the feed URL for the business category
- Paste the feed URL into Pabbly Connect
After pasting the URL, set the filter type to ‘Default Recommended’ and click on ‘Save and Send Test Request’. This will allow Pabbly Connect to capture the latest feed item, confirming that the trigger is working correctly.
4. Connecting Telegram Bot in Pabbly Connect
Once the Trigger is set up, move to the Action section and select ‘Telegram Bot’ as your application. For the Action Event, choose ‘Send a Text Message’. This will enable you to send the RSS feed updates to your Telegram channel.
To connect the Telegram Bot, you must create a bot using the BotFather in Telegram. Follow these steps:
Search for ‘BotFather’ in Telegram Start a chat and create a new bot Copy the token provided by BotFather
Paste this token into Pabbly Connect to establish the connection. Make sure to add the bot to your Telegram group and set it as an admin to allow it to send messages.
5. Finalizing the Telegram Message in Pabbly Connect
After connecting the Telegram bot, you will need to specify the chat ID where the messages will be sent. This chat ID can be found in the URL of your Telegram group. Paste this ID into Pabbly Connect.
Next, create the message content. You can include a static text like ‘Just dropped a fresh update on my RSS feed: ‘ followed by dynamic data from the previous step, such as the RSS feed title. Here’s how to do it:
Map the title of the RSS feed from the previous step Include the link to the RSS feed Click on ‘Save and Send Test Request’ to test the setup
Once the test is successful, you will see the message posted in your Telegram group, confirming that the automation works. This integration of RSS by P and Telegram through Pabbly Connect ensures your subscribers receive timely updates.
In this tutorial, we demonstrated how to use Pabbly Connect to automate posting The Hindu RSS feed on Telegram. By following these steps, you can ensure that your subscribers stay updated with the latest news effortlessly. This integration not only saves time but also enhances communication with your audience.
