Learn how to integrate Uteach and MailerLite automatically using Pabbly Connect. Follow this step-by-step tutorial for seamless email marketing. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start the process of adding Uteach students to MailerLite as subscribers automatically, you will first need to access Pabbly Connect. Begin by visiting the Pabbly website and signing in to your account. If you are a new user, you can sign up for a free account to get started.
Once you are signed in, navigate to the Pabbly Connect dashboard. Here, you will find the option to create a new workflow. Click on the ‘Create Workflow’ button, which allows you to set up the automation that connects Uteach and MailerLite seamlessly.
2. Creating the Workflow in Pabbly Connect
In this step, you will create the workflow that connects Uteach to MailerLite using Pabbly Connect. Name your workflow appropriately, such as ‘Add Uteach Students to MailerLite as Subscribers Automatically.’ Select the folder where you want to save this workflow.
- Select Uteach as the trigger application.
- Choose ‘New Student’ as the trigger event.
After selecting the trigger application and event, click on the connect button. You will need to add a new connection by providing your Uteach domain and API key, which can be found in the Uteach dashboard under settings. Enter these details to establish the connection between Uteach and Pabbly Connect.
3. Testing the Connection with Uteach
After setting up the trigger, it’s essential to test the connection to ensure that everything is functioning correctly. Once you have connected Uteach to Pabbly Connect, click on ‘Save and Send Test Request’ to initiate a test. This action will prompt you to create a new student in your Uteach account.
Go to your Uteach registration page and fill out the registration form with test data. For instance, you can use a name like ‘Demo User’ and an email like ‘[email protected]’. After registering, return to Pabbly Connect to check if the test submission was successful.
4. Setting Up MailerLite as the Action Application
Now that the Uteach trigger is confirmed, you will set up MailerLite as the action application in Pabbly Connect. Search for MailerLite and select it as the action application. Choose ‘Create or Update Subscriber’ as the action event.
Connect your MailerLite account by adding a new connection, which will require your API key from MailerLite. To find this, navigate to the integration settings in your MailerLite account and generate a new API key. Once you have the key, paste it into Pabbly Connect to establish the connection.
- Map the subscriber email from the Uteach response to ensure it dynamically updates.
- Set the subscriber status to active and choose the appropriate group in MailerLite.
- Complete the mapping for the subscriber name as well.
Finally, click on ‘Save and Send Test Request’ to verify that a new subscriber is created in MailerLite based on the student data from Uteach. This step is crucial to confirm the successful integration.
5. Verifying the Integration Success
Once you have completed the setup, it’s time to verify that the integration between Uteach and MailerLite via Pabbly Connect is working effectively. After performing the test submission in Uteach, check your MailerLite account to see if the new subscriber has been added successfully.
Log in to MailerLite and navigate to the subscribers’ section. Here, you should see the email address of the test user you registered in Uteach. If the subscriber appears, it confirms that the integration is functioning as intended, allowing you to automate your email marketing efforts.
To summarize, you have successfully created a workflow in Pabbly Connect that connects Uteach to MailerLite, allowing you to add new students as subscribers automatically. This integration streamlines your marketing efforts and enhances your ability to reach potential customers effectively.
In this tutorial, we explored how to add Uteach students to MailerLite as subscribers automatically using Pabbly Connect. This integration simplifies the process of managing your email list and enhances your marketing capabilities. By following these steps, you can ensure a smooth workflow that captures new leads effortlessly.
