Learn how to seamlessly integrate WooCommerce with AWeber using Pabbly Connect to add tags to subscribers for new orders. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Setting Up Pabbly Connect for WooCommerce and AWeber Integration
To start the integration process, we will use Pabbly Connect. This platform allows us to automate the tagging of AWeber subscribers whenever a new order is placed in WooCommerce. First, access your Pabbly Connect dashboard by signing up for a free account.
Once you are on the dashboard, click on ‘Create Workflow’ and name it, for example, ‘WooCommerce to AWeber’. This workflow will handle the automation of adding tags to your AWeber subscribers based on new WooCommerce orders.
2. Setting the Trigger to Capture New WooCommerce Orders
In this step, we will set up the trigger in Pabbly Connect to capture new orders from WooCommerce. Select WooCommerce as the app and choose the trigger event as ‘New Order Created’. This step is crucial as it determines when the automation will be activated.
- Select WooCommerce from the app list.
- Choose the trigger event as ‘New Order Created’.
After copying the webhook URL, navigate to your WooCommerce settings. Under the Advanced tab, select Webhooks, and create a new webhook. Name it, set the status to active, and select ‘Order Created’ as the topic. Paste the copied webhook URL in the delivery URL field and save the webhook.
3. Testing the Trigger in Pabbly Connect
Now that the trigger is set, we will test it to ensure that Pabbly Connect is receiving data from WooCommerce correctly. Click on the ‘Recapture Webhook Response’ button in your workflow. This action puts Pabbly Connect in a waiting state for a response from WooCommerce.
To generate a response, place a test order in your WooCommerce store. Fill in the customer details and submit the order. After placing the order, return to Pabbly Connect to check for the incoming response. You should see the order details captured in the workflow.
4. Setting Up AWeber Action to Add or Update Subscribers
Next, we will set up the action in Pabbly Connect to add or update the subscriber in AWeber. Choose AWeber as the app and select ‘Add or Update Subscriber’ as the action event. This action allows us to either add a new subscriber or update an existing one based on the order details.
- Select AWeber from the app list.
- Choose ‘Add or Update Subscriber’ as the action event.
- Connect your AWeber account to Pabbly Connect.
After connecting, map the required fields such as full name and email address from the WooCommerce order response. Additionally, set the ‘Update Existing Contact’ option to yes, allowing for tags to be added to existing subscribers.
5. Adding Tags to AWeber Subscribers via Pabbly Connect
In this final step, we will add tags to the AWeber subscribers. Within the action setup in Pabbly Connect, you can specify tags based on the order details. For example, you can add a tag like ‘Customer’ and the name of the product ordered.
After mapping the tags, click on ‘Save and Send Test Request’. This action will send the data to AWeber. Check your AWeber account to verify that the subscriber has been added with the correct tags. You should see the subscriber’s details along with the tags reflecting the order they made.
This integration demonstrates how Pabbly Connect streamlines the process of managing subscribers based on WooCommerce orders, enhancing your marketing efforts with AWeber.
This tutorial has shown how to effectively use Pabbly Connect to automate the process of adding tags to AWeber subscribers for new WooCommerce orders. By integrating these platforms, you can efficiently manage your customer relationships and enhance your email marketing strategies.
