Learn how to add subscribers to different MailerLite groups using Pabbly Connect and Razorpay payments. Step-by-step tutorial for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To add subscribers to different MailerLite groups using Razorpay payments, you first need to set up Pabbly Connect. This tool acts as the integration platform that connects Razorpay and MailerLite seamlessly. Start by signing in to your Pabbly Connect account or create a new one if you are a first-time user.
Once logged in, navigate to the dashboard. Click on the ‘Create Workflow’ button located at the top right corner. Name your workflow appropriately, such as ‘Razorpay to MailerLite’, and save it in your desired folder. This initial setup is crucial for organizing your automation processes.
2. Defining Trigger and Action in Pabbly Connect
In this step, you will define the trigger and action for your automation in Pabbly Connect. The trigger application is Razorpay, while the action application is MailerLite. Select Razorpay as your trigger application and choose the trigger event as ‘Payment Captured’.
  • Select Razorpay as the trigger application.
  • Choose ‘Payment Captured’ as the trigger event.
  • Copy the provided webhook URL to connect Razorpay with Pabbly Connect.
After setting the trigger, go to your Razorpay account and navigate to the account settings. Under the Webhooks section, add a new webhook using the URL copied from Pabbly Connect. This establishes a link between the two applications, enabling data transfer.
3. Testing Payment and Receiving Data in Pabbly Connect
With the webhook set up, it’s time to test the payment process. Make a test purchase on your Razorpay payment page. Fill in the required details, including course name, first name, last name, email, and payment information. Once the payment is processed, you should see a successful response in Pabbly Connect.
During this process, ensure that the payment details such as order ID, customer name, and email are captured correctly. This data will be essential for adding subscribers to MailerLite. The automation process will now begin as soon as a payment is captured.
4. Adding Subscriber to MailerLite Based on Payment
After confirming that the payment details have been captured, the next step is to add the subscriber to the appropriate MailerLite group. In Pabbly Connect, set up a router to manage different routes based on the course purchased. Create routes for each course, such as ‘PHP Programming Course’ and ‘Java for Beginners’.
  • Create a route for PHP Programming Course.
  • Create a route for Java for Beginners.
  • Set filters to ensure the correct subscriber is added based on course selection.
For each route, configure the action to add or update the subscriber in MailerLite. Map the email, first name, last name, and phone number from the Razorpay payment details to the corresponding fields in MailerLite. This ensures that the subscriber information is dynamically updated with every new purchase.
5. Finalizing the Integration and Confirmation
After configuring the subscriber addition in MailerLite, test the workflow to ensure everything is functioning correctly. Make another test purchase for a different course, such as ‘Java for Beginners’, and verify that the subscriber is added to the appropriate group in MailerLite.
Once the test is successful, you can confirm that the integration is working as intended. Subscribers will automatically be added to their respective groups based on the course they purchased, streamlining your email marketing efforts. This integration using Pabbly Connect ensures that your subscriber list is always up-to-date.
In this tutorial, we explored how to add subscribers to different MailerLite groups using Razorpay payments through Pabbly Connect. By following the steps outlined, you can automate the process and ensure seamless integration between these applications, enhancing your email marketing capabilities.
