Learn how to add students to Uteach courses through ThriveCart payments and create ConvertKit subscribers using Pabbly Connect in this detailed tutorial. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To begin integrating Uteach with ThriveCart and ConvertKit, access Pabbly Connect. This powerful automation tool facilitates seamless connections between your applications. Start by visiting the Pabbly Connect website and signing up or logging in if you are an existing user.
Once you are logged in to Pabbly Connect, you will see the dashboard. Here, you can create a new workflow that will automate the process of adding students to Uteach after a ThriveCart payment is made. Follow the prompts to set up your automation effectively.
To create a workflow in Pabbly Connect, click on the ‘Create Workflow’ button located in the top right corner of the dashboard. Name your workflow something descriptive, such as ‘Add Students to Uteach Course on ThriveCart Payment’. Select a folder for organization purposes.
  • Understand that your workflow will consist of a trigger and one or more actions.
  • Triggers initiate the workflow, while actions are the tasks executed in response.
With your workflow created, it’s time to set a trigger. In this case, you will select ThriveCart as your trigger application, which will activate the workflow whenever a new product purchase occurs.
3. Setting Up the ThriveCart Trigger
In this step, select ThriveCart as your trigger application in Pabbly Connect. Choose the trigger event as ‘Product Purchase’. This ensures that the workflow activates each time a customer makes a purchase through ThriveCart.
To connect ThriveCart with Pabbly Connect, you will need to enter your API token. Log into your ThriveCart account, navigate to your profile settings, and find the API and webhooks section. Generate a new API key, copy it, and paste it into Pabbly Connect.
  • Ensure to select the correct product you want to track.
  • Set the product status to test mode for initial testing.
  • Click ‘Save and Send Test Request’ to verify the connection.
After setting up the trigger, perform a test purchase to confirm that Pabbly Connect captures the response correctly. This will be essential for the next steps in the automation process.
4. Adding Student to Uteach Course
With the trigger successfully set, the next action is to add the student to Uteach using Pabbly Connect. Select Uteach as your action application and choose the action event as ‘Create Student’. This action will ensure that whenever a purchase is made, the customer is automatically added as a student in Uteach.
Connect Uteach to Pabbly Connect by entering the required domain and API key. Similar to ThriveCart, you will find these details in your Uteach account under settings and integrations. After entering the details, click ‘Save’ to establish the connection.
Map the customer’s name and email from the ThriveCart trigger response. Click ‘Save and Send Test Request’ to confirm the student was added successfully. Verify in your Uteach account that the new student appears in the user list.
This step ensures that all new customers who purchase courses are enrolled in Uteach automatically, streamlining your enrollment process.
5. Creating a ConvertKit Subscriber
The final action in this workflow is to create a subscriber in ConvertKit using Pabbly Connect. Select ConvertKit as your action application and choose the action event as ‘Add Subscriber to Form’. This will allow you to automatically add the student to your email list after they enroll in the course.
Connect ConvertKit with Pabbly Connect by entering your API key and API secret, which can be found in your ConvertKit account settings under the Advanced section. Once connected, you can map the relevant fields such as first name, last name, and email.
Select the form you want to add subscribers to. Map the fields from the previous steps to ensure data flows correctly. Click ‘Save and Send Test Request’ to confirm the subscriber was added successfully.
After completing these steps, you can verify in your ConvertKit account that the subscriber has been created. This integration ensures that all students who enroll in your courses are also added to your email marketing lists, enhancing your communication strategy.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate ThriveCart, Uteach, and ConvertKit. By automating the process of adding students to Uteach and creating subscribers in ConvertKit, you can streamline your online course management and marketing efforts effectively. This integration not only saves time but also enhances the overall experience for your students and leads.
