Learn how to integrate Elementor with ThriveCart Learn+ using Pabbly Connect for seamless student enrollment. Step-by-step tutorial included. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
1. Introduction to Pabbly Connect for Elementor and ThriveCart Learn+
Pabbly Connect is an essential tool that allows you to automate workflows between various applications, including Elementor and ThriveCart Learn+. In this tutorial, we will explore how to add students to ThriveCart Learn+ from Elementor form submissions using Pabbly Connect. using Pabbly Connect
To begin, ensure you have access to your Pabbly Connect account. If you are new, you can sign up for free and get started with automation. This integration will enable you to capture leads from your Elementor forms and automatically enroll them in your ThriveCart Learn+ courses.
2. Setting Up Pabbly Connect for Integration
To set up the integration, log into your Pabbly Connect account and navigate to the dashboard. Click on the ‘Create Workflow’ button to initiate the process. You will need to name your workflow, for example, ‘Add Students to ThriveCart Learn+ from Elementor Form Submission.’ This name will help you identify the workflow later. using Pabbly Connect
- Select ‘Elementor’ as your trigger application.
After selecting Elementor, Pabbly Connect will provide you with a webhook URL. This URL will be used to connect your Elementor form with Pabbly Connect. Copy this URL and proceed to your Elementor account.
3. Configuring Elementor to Work with Pabbly Connect
In your Elementor account, navigate to the form you created for course enrollment. Click on the form widget and go to the ‘Actions After Submit’ section. Here, you will add a new action for the webhook. using Pabbly Connect
Add the webhook action and paste the URL you copied from Pabbly Connect into the designated field. Click on ‘Update’ to save your changes. Once this is done, your Elementor form is now connected to Pabbly Connect, and submissions will trigger the workflow.
- Ensure that you have added the webhook action correctly.
- Test the form by submitting dummy details to verify the connection.
After submitting a test form, check your Pabbly Connect workflow to see if the details have been captured successfully. This confirms that the integration between Elementor and Pabbly Connect is functioning correctly.
4. Adding Google Sheets to Capture Leads
Now that your Elementor form is integrated with Pabbly Connect, the next step is to add Google Sheets to capture the lead details. In your Pabbly Connect workflow, select Google Sheets as the action application. using Pabbly Connect
Choose ‘Add New Row’ as the action event and connect your Google Sheets account. If this is your first time connecting, follow the prompts to authorize Pabbly Connect to access your Google Sheets. Once connected, select the spreadsheet where you want to store the leads.
Map the fields from the Elementor submission to the corresponding columns in Google Sheets. Click on ‘Save and Send Test Request’ to verify that the data is being added correctly.
After completing this step, check your Google Sheets to ensure that the lead details have been recorded. This allows you to maintain a record of all new leads captured through your Elementor forms.
5. Enrolling Students in ThriveCart Learn+
The final step is to enroll the captured leads into your ThriveCart Learn+ course. In your Pabbly Connect workflow, add another action, and select ThriveCart Learn+ as the application. using Pabbly Connect
Choose ‘Create New Student’ as the action event and connect your ThriveCart Learn+ account. You will need to provide the API key from your ThriveCart account to establish this connection. Once connected, map the necessary fields, such as name and email, from the Elementor submission.
Make sure to include the course ID for the course you want to enroll students in. Click on ‘Save and Send Test Request’ to finalize the enrollment process.
Once the test request is successful, check your ThriveCart Learn+ account to confirm that the new student has been enrolled. This integration allows for seamless enrollment of leads captured through your Elementor forms into your courses.
In this tutorial, we demonstrated how to integrate Elementor with ThriveCart Learn+ using Pabbly Connect. By following these steps, you can automate the process of capturing leads and enrolling them in your courses effortlessly. This not only saves time but also helps you convert leads into customers effectively.
