Learn how to seamlessly integrate ConvertKit and ThriveCart Learn using Pabbly Connect to automate student enrollments with our step-by-step guide. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To automate student enrollment in ThriveCart Learn from ConvertKit form submissions, you first need to access Pabbly Connect. This platform allows you to create workflows that connect multiple applications seamlessly.
Once logged in, you can create a free account on Pabbly Connect. This account provides access to a dashboard where you can set up your automation. Click on the ‘Create Workflow’ button and name your workflow, such as ‘Add Student to Course in ThriveCart from ConvertKit’.
2. Setting Up the Trigger Event in Pabbly Connect
In this step, you will set up the trigger event for your workflow in Pabbly Connect. Select ConvertKit as your first application and choose the trigger event, which is ‘New Form Subscriber’. This event will initiate the workflow whenever a user submits a form.
Next, connect your ConvertKit account by entering the API key and secret. You can find these in your ConvertKit account settings under the API section. After connecting, select the specific form you created for course sign-ups.
- Log in to ConvertKit and navigate to account settings.
- Copy the API key and secret from the API section.
- Return to Pabbly Connect and paste the credentials to connect.
After saving the connection, you can test the trigger to ensure it captures the data correctly from the form submissions.
3. Testing the Trigger with Dummy Data
To ensure that your trigger is working correctly, you need to test it by submitting dummy data through the ConvertKit form. This step is crucial for verifying that Pabbly Connect is receiving the correct information.
Open your ConvertKit form and submit a test entry with dummy user details. After submission, return to the Pabbly Connect dashboard and check if the data is captured. You should see fields like subscriber ID, name, email, and phone number reflecting the submitted data.
- Submit a test entry using the ConvertKit form link.
- Confirm the email address if required for the submission.
- Check Pabbly Connect for the captured data response.
Once the data appears in Pabbly Connect, your trigger setup is successful, and you can proceed to the next step of the workflow.
4. Adding Student to ThriveCart Learn
Now, it’s time to add the captured user as a student in ThriveCart Learn using Pabbly Connect. Select ThriveCart as your second application and choose the action event ‘Create New Student’. This action will enroll users automatically into the specified course.
To connect ThriveCart with Pabbly Connect, you will need to enter the API key from your ThriveCart account. Navigate to the API settings in ThriveCart, copy the key, and paste it into Pabbly Connect. Then, map the fields from the ConvertKit trigger to the ThriveCart action, ensuring that the email and name fields are correctly linked.
Select the course ID from the ThriveCart URL for the course you want to enroll students in. Map the first name and last name from the ConvertKit data to the ThriveCart fields. Leave optional fields blank unless necessary.
After mapping the fields, click on ‘Save and Send Test Request’. If successful, the user will be enrolled in your ThriveCart course, confirming that the integration through Pabbly Connect works flawlessly.
5. Conclusion
Automating student enrollment in ThriveCart Learn from ConvertKit submissions is straightforward with Pabbly Connect. By following the steps outlined above, you can ensure that every new form submission results in automatic enrollment, saving you time and effort.
This integration not only streamlines your workflow but also enhances the user experience for your students. With Pabbly Connect, you can focus on creating great content while the automation takes care of the enrollment process.
