Learn how to integrate ThriveCart Learn with Razorpay using Pabbly Connect to automate student enrollment upon payment. Step-by-step tutorial included. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To start integrating ThriveCart Learn with Razorpay, we will use Pabbly Connect. First, access the Pabbly Connect dashboard by signing up for a free account. Once logged in, you can create an automation workflow to connect Razorpay and ThriveCart Learn.
After logging into Pabbly Connect, click on the ‘Create Workflow’ button. Name your workflow accordingly, for example, ‘Razorpay to ThriveCart Learn’. Select the appropriate folder in your Pabbly Connect account and click on ‘Create’ to proceed with the setup.
Setting Up the Trigger for Razorpay Payments
In this section, we will configure the trigger to capture payments made via Razorpay. Start by selecting Razorpay as the app in the trigger window of Pabbly Connect. Choose ‘Payment Captured’ as the trigger event, which will activate the automation whenever a payment is received.
Once you select the trigger event, Pabbly Connect will provide a webhook URL. Copy this URL to connect your Razorpay account. Navigate to the Razorpay dashboard, and under ‘Account and Settings’, find the ‘Webhooks’ section. Click on ‘Add New Webhook’ and paste the copied URL. Set the active event to ‘Payment Captured’ and click ‘Create’.
  • Select Razorpay as the app in Pabbly Connect.
  • Choose ‘Payment Captured’ as the trigger event.
  • Add the webhook URL in Razorpay and select the active event.
After creating the webhook, Pabbly Connect will wait for a response from Razorpay. This indicates that the connection is successfully established and ready to capture payment details.
Filtering Payments for Student Enrollment
Next, we will filter the payments to ensure that only customers who purchased the specific course are added as students in ThriveCart Learn. In this step, you will set a filter condition in Pabbly Connect to check if the course selected during payment matches the course in ThriveCart Learn.
To add a filter, select ‘Filter’ as the app in the action step of Pabbly Connect. Set the filter type to ‘Equals’ and specify the course name from Razorpay. This way, only those payments that match the course name will proceed to the next step of adding the student.
  • Select ‘Filter’ as the app in the action step.
  • Set the filter type to ‘Equals’.
  • Specify the course name to filter payments.
Once the filter is set, Pabbly Connect will only allow payments that match the specified course to proceed to the next action, ensuring that only the right customers are enrolled as students in ThriveCart Learn.
Adding Students to ThriveCart Learn
In the final step, we will add the filtered customers as students in ThriveCart Learn using Pabbly Connect. Select ThriveCart Learn as the app in the action step and choose ‘Create New Student’ as the action event. This step will allow you to enroll the customer automatically.
To connect your ThriveCart Learn account, you will need to provide the API key. Retrieve the API key from your ThriveCart Learn account settings. After entering the API key in Pabbly Connect, map the required fields such as customer email, course ID, and name.
Select ThriveCart Learn as the app in the action step. Choose ‘Create New Student’ as the action event. Map the customer email, course ID, and name.
After mapping the fields, click on ‘Save and Send Test Request’. If successful, the customer will be added as a student in ThriveCart Learn, confirming that the automation via Pabbly Connect is functioning correctly.
In this tutorial, we learned how to integrate ThriveCart Learn with Razorpay using Pabbly Connect. This integration automates the process of adding students upon payment, making it efficient and seamless. With Pabbly Connect, you can streamline your online course management effectively.
