Learn how to add students in ThriveCart Learn automatically using Pabbly Connect with Swipe Pages. Follow this detailed tutorial for seamless integration. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To begin integrating Swipe Pages with ThriveCart Learn, access Pabbly Connect. This platform is essential for automating the process of adding students from orders received via Swipe Pages.
Start by visiting the Pabbly website. If you don’t have an account, you can easily sign up for free. Once signed in, navigate to the Pabbly Connect dashboard by clicking the ‘Access Now’ button. This will take you to the workflow section where you can create a new integration.
In this section, you will create a new workflow in Pabbly Connect to manage the process of adding students automatically. Click on the ‘Create Workflow’ button and name your workflow, such as ‘Add Student in ThriveCart Learn on Swipe Pages Sale’.
- Select the folder where you want to save your workflow.
- Set up the trigger application as Swipe Pages.
- Choose ‘New Order’ as your trigger event.
After setting the trigger, you will need to connect Swipe Pages with Pabbly Connect using the provided webhook URL. This URL acts as a bridge for data transfer between the two applications.
3. Setting Up Swipe Pages for Data Transfer
Next, configure your Swipe Pages account to send data to Pabbly Connect. Create a landing page for your course and set up the integration by clicking on ‘Get Started’.
- Name your workflow in Swipe Pages, for example, ‘ThriveCart Courses’.
- Select the trigger for order processing.
- Map the required order details such as full name, email, and shipping address.
Once you have set up the webhook and mapped the necessary fields, run a test to ensure that data is being sent correctly to Pabbly Connect.
4. Adding a Student in ThriveCart Learn Using Pabbly Connect
Now that your webhook is set up, it’s time to add a student in ThriveCart Learn using Pabbly Connect. For this, select ThriveCart as your action application and choose ‘Create New Student’ as your action event.
To connect ThriveCart with Pabbly Connect, you will need an API key from your ThriveCart account. Navigate to the settings in ThriveCart, create a new API key, and paste this key into Pabbly Connect to establish the connection.
Input the email address of the student using the mapped data from Swipe Pages. Specify the course ID for the Java course. Complete the required fields and save the configuration.
After saving, run a test request to verify that the student has been successfully added to your ThriveCart course.
With the setup complete, return to Pabbly Connect to finalize the integration. Monitor the data received from Swipe Pages to ensure that all information is correct and is being processed as expected.
To test the integration, create a new order in your Swipe Pages account. Fill in the order details and complete the payment process. Once the order is successful, check ThriveCart to confirm that the student has been added automatically.
By following these steps, you can successfully automate the process of adding students in ThriveCart Learn using Pabbly Connect and Swipe Pages. This integration not only saves time but also enhances the efficiency of managing course enrollments.
This tutorial detailed how to leverage Pabbly Connect to add students in ThriveCart Learn automatically when new orders are placed through Swipe Pages. By following the steps outlined, you can streamline your course management process effectively.
