Learn how to integrate ThriveCart and Uteach to automate student enrollment using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To begin the integration process, you need to access Pabbly Connect. Start by searching for Pabbly Connect in your browser. This will take you to the Pabbly Connect landing page where you can either sign in or sign up for a free account.
If you are new to Pabbly Connect, click on the ‘Sign up for free’ button. This quick process will give you 100 free tasks each month. Once logged in, you will see the dashboard with various applications available for integration, including ThriveCart and Uteach.
In this section, you will create a new workflow to automate student enrollment. Click on the ‘Create Workflow’ button on your Pabbly Connect dashboard. A window will pop up asking you to name your workflow; name it ‘Add Student to Uteach Bundle from ThriveCart Purchase’. using Pabbly Connect
  • Select the folder where you want to save your workflow.
Once created, you will see two boxes: Trigger and Action. The Trigger box will be set up first. Click on the Trigger box and search for ThriveCart as your trigger application.
3. Setting Up the Trigger for ThriveCart
For the trigger event, select ‘Product Purchase’ from the dropdown menu. You will need to connect ThriveCart with Pabbly Connect to proceed. Click on ‘Connect’ and then ‘Add New Connection’.
To connect ThriveCart, you will need an API token. Navigate to your ThriveCart profile, go to settings, and find the API section. Here, create a new API key named ‘Uteach Enrollment’ and copy this key.
  • Paste the API key back into Pabbly Connect.
  • Select the product you want to sell and set the product status (test or live).
Click on ‘Save and Send Test Request’ to check for responses. This will confirm that your trigger is correctly set up.
4. Setting Up the Action for Uteach
Now, you will set up the action that occurs after the trigger. In the Action box, select Uteach as your action application. For the action event, choose ‘Create Student’.
You will need to connect Uteach with Pabbly Connect as well. Click on ‘Connect’, then ‘Add New Connection’. You will need to provide your Uteach domain and API key, which can be found in your Uteach account settings under Integrations.
Map the student’s name and email address from the ThriveCart response. Click on ‘Save and Test’ to ensure the student is created successfully.
After saving, you should see a positive response indicating that the student has been successfully created in Uteach.
5. Adding Student to Uteach Bundle
The final step is to add the newly created student to your course bundle in Uteach. Again, select Uteach in the Action box and choose ‘Add Student to Bundle’ as your action event. using Pabbly Connect
Connect using the existing connection you made earlier. You will need to map the student’s email and provide the bundle slug for your course. To find the bundle slug, go to Uteach, navigate to Marketing, and find your bundles.
Copy the slug from the URL after the last slash. Paste it back into Pabbly Connect.
Click on ‘Save and Test’ to confirm that the student has been added to your bundle. You should see a confirmation response, indicating that the integration is complete.
This tutorial demonstrated how to use Pabbly Connect to automate the process of adding students to a Uteach bundle following a ThriveCart purchase. By following these steps, you can streamline your enrollment process and enhance the learning experience for your students.
