Learn how to automate the integration of social media posts on WordPress using Pabbly Connect. This step-by-step guide covers everything you need to know. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To automate social media posts on WordPress instantly, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website where you can either sign in or create a free account.
Once logged in, you will find the dashboard where you can create and manage your workflows. This is the central hub for integrating your applications without any coding skills. Here’s how to get started:
  • Visit the Pabbly Connect website.
  • Sign in or create a new account.
  • Access your dashboard to create workflows.
With your account set up, you are ready to create a workflow that connects Instagram and WordPress using Pabbly Connect.
Now that you have accessed Pabbly Connect, it’s time to create a new workflow. Click on the ‘Create Workflow’ button and give your workflow a name like ‘Add Social Media Post on WordPress Instantly’.
After naming your workflow, select the folder where you want to save it. This helps in organizing your workflows efficiently. Once done, you will see two sections: Trigger and Action. The trigger will be your Instagram account, and the action will be WordPress.
  • Select the folder for organization.
  • Choose Instagram as the trigger and WordPress as the action.
This workflow setup is crucial as it defines how posts from Instagram will be shared on your WordPress site using Pabbly Connect.
3. Setting Up the Instagram Trigger
To begin the integration process, you need to set up the trigger for Instagram in Pabbly Connect. Select ‘Instagram for Business’ as your trigger application and choose the trigger event as ‘New Media Posted’.
This event will activate the workflow whenever a new post is shared on your Instagram account. Once selected, click on ‘Connect’ to establish the connection between Instagram and Pabbly Connect. If you already have an existing connection, you can select that; otherwise, you will need to create a new connection.
Select ‘Instagram for Business’ as the trigger application. Choose ‘New Media Posted’ as the trigger event. Connect your Instagram account to Pabbly Connect.
Once the connection is established, you can test the trigger to ensure it captures the latest post from Instagram, setting the stage for the next steps in your automation process.
4. Configuring the WordPress Action
Now that your Instagram trigger is set, it’s time to configure the action for WordPress in Pabbly Connect. Select ‘WordPress’ as the action application and choose the action event as ‘Create a Post’.
Click on ‘Connect’ and enter your WordPress credentials, including your username, password, and base URL. Ensure that the base URL does not include ‘wp-admin’ to successfully establish a connection with Pabbly Connect.
Select ‘WordPress’ as the action application. Choose ‘Create a Post’ as the action event. Enter your WordPress credentials correctly.
With this action configured, you can now map the details from the Instagram post, such as the title and link, to create a post on your WordPress site automatically.
5. Testing the Integration and Finalizing
After setting up both the trigger and action, it’s crucial to test the integration. Click on ‘Save and Send Test Request’ in Pabbly Connect to check if the data from Instagram is correctly received and mapped to WordPress.
Make sure to check the response to confirm that the post is created successfully on WordPress with the correct title and link. Once verified, you can start using this automation to share your social media posts instantly on WordPress without any manual effort.
Test the integration to ensure everything works as expected. Verify the response for successful post creation. Start automating your social media posts on WordPress.
This final step ensures that your workflow is functioning correctly, allowing you to automate the posting process seamlessly using Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to automate the posting of social media content on WordPress instantly. By integrating Instagram with WordPress, you can save time and effort while ensuring your posts reach a wider audience. This automation streamlines your workflow and enhances your online presence.
