Learn how to automate adding received KrispCall SMS to Airtable using Pabbly Connect. Follow this step-by-step guide for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Setting Up Pabbly Connect for KrispCall and Airtable Integration
To start integrating KrispCall SMS with Airtable, you need to set up Pabbly Connect. This platform allows you to automate the process of adding SMS details to Airtable whenever you receive a new message. Begin by visiting the Pabbly Connect website and signing in or signing up for a free account.
Once you’re logged in, navigate to your dashboard. Here, click on the ‘Create Workflow’ button to initiate a new automation. Name your workflow appropriately, such as ‘Add Received KrispCall SMS to Airtable,’ and save it in a relevant folder. This setup is crucial for organizing your automations effectively.
2. Configuring Trigger and Action in Pabbly Connect
In this step, you’ll configure the trigger and action for your automation using Pabbly Connect. The trigger application will be KrispCall, and the action application will be Airtable. Search for KrispCall in the trigger window and select ‘New SMS or MMS’ as the trigger event. This ensures that the automation starts whenever a new SMS is received.
- Select KrispCall as the trigger application.
- Choose ‘New SMS or MMS’ as the trigger event.
- Proceed to configure the action application, which is Airtable.
For the action, search for Airtable and select ‘Create New Record’ as the action event. This setup allows you to automatically create a new record in Airtable whenever a new SMS is received through KrispCall. After configuring both the trigger and action, click on the ‘Connect’ button to establish a connection between KrispCall and Pabbly Connect.
3. Connecting KrispCall to Pabbly Connect
To connect KrispCall with Pabbly Connect, you need to provide the API key and secret key from your KrispCall account. Go to your KrispCall dashboard, navigate to the settings, and then to the developer section to find these keys. Copy both keys and paste them into the respective fields in Pabbly Connect.
After entering the keys, click on ‘Save’ to establish the connection. Once the connection is successful, you can test it by sending a sample SMS to your registered KrispCall number. This test will help you verify that the integration is functioning correctly.
4. Adding SMS Details to Airtable
Now that you have successfully connected KrispCall to Pabbly Connect, it’s time to add the SMS details into Airtable. First, you need to connect your Airtable account by clicking on ‘Connect’ in the action section. Make sure you are logged into your Airtable account in another tab for seamless access.
- Click on ‘Grant Access’ to allow Pabbly Connect to access your Airtable account.
- Select the base name and table name where you want to add the SMS details.
- Map the fields from the SMS details to the corresponding Airtable fields.
Mapping is crucial as it ensures that the correct data is inserted into the right fields. For instance, map the sender’s number, the SMS content, and the ID into their respective fields. Once you have completed the mapping, click on ‘Save and Send Test Request’ to verify that the SMS details are added correctly to Airtable.
5. Conclusion: Automate SMS to Airtable Using Pabbly Connect
By following these steps, you have successfully set up an automation using Pabbly Connect to add received KrispCall SMS into Airtable. This integration streamlines the process, allowing you to manage SMS communications efficiently. Whenever a new SMS is received, the details will automatically populate in your Airtable account, enhancing your workflow.
This automation not only saves time but also ensures that you never miss important messages. With Pabbly Connect, you can explore more integrations and automations to improve your productivity further.
