Learn how to integrate Pinterest and Nuelink collection posts using Pabbly Connect in this detailed tutorial. Follow the step-by-step process to automate your workflow. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
1. Accessing Pabbly Connect to Start the Integration
To begin the integration process, you need to access Pabbly Connect. Start by searching for Pabbly.com/connect in your browser. This action will direct you to the Pabbly Connect landing page.
If you do not have an account, click on the ‘Sign up for free’ button to create an account, which takes only a couple of minutes. If you already have an account, simply sign in to access the dashboard.
Once logged into Pabbly Connect, you need to create a new workflow. Click on the ‘Create Workflow’ button, which will open a pop-up window for naming your workflow. Name it something descriptive, like ‘Add Nuelink Collection Post from Pinterest Pin,’ and click ‘Create’ to proceed.
  • Click the ‘Create Workflow’ button.
  • Click ‘Create’ to move on to the next step.
You will now see two boxes labeled ‘Trigger’ and ‘Action’. The trigger is the event that starts the workflow, while the action is what happens as a result. In this case, the trigger will be a new pin added to Pinterest.
3. Setting Up the Trigger for Pinterest Pin
In the trigger box, search for and select ‘Pinterest’ as your trigger application. Then, choose the trigger event ‘New Pin for Specific Board’. This event will allow Pabbly Connect to detect any new pins added to your specified Pinterest board.
Next, click on ‘Connect’ to establish a connection between your Pinterest account and Pabbly Connect. You will need to authorize Pabbly Connect to access your Pinterest account, which is done by clicking the ‘Give Access’ button. Once successfully connected, you can select the specific board you want to monitor for new pins.
4. Adding a New Pin in Pinterest
After setting up the trigger, the next step is to create a new pin in your Pinterest account. Click on the plus icon and select ‘Create Pin’. Choose the image you wish to use and fill in the title and description for your pin. For instance, you might set the title as ‘Nature Splender’ and add a descriptive caption.
  • Click the plus icon in Pinterest.
  • Choose ‘Create Pin’ and upload your image.
  • Add a title and description before publishing.
Once published, return to Pabbly Connect and click the ‘Save and Test’ button. This action will retrieve the details of the newly created pin, including the title, image URL, and description, which will be used for the next step in the workflow.
5. Finalizing the Action to Add Post in Nuelink
With the details of your new Pinterest pin retrieved, it’s time to set up the action in Pabbly Connect. Search for and select ‘New Link’ as your action application. Choose the action event ‘Add Post to Collection’. This will allow you to add a new post to your Nuelink collection based on the details from the Pinterest pin.
Connect your New Link account to Pabbly Connect by clicking ‘Connect’ and then ‘Add New Connection’. You will need to select the brand and collection where you want to add the post. Once connected, map the Pinterest response fields to the New Link fields, ensuring that the title, media URL, and description are correctly populated.
Finally, click the ‘Save and Send Test’ button to complete the process. If successful, you will see a confirmation response indicating that the new post has been added to your Nuelink collection. This integration will now run automatically whenever a new pin is added to your specified Pinterest board.
In this tutorial, we explored how to use Pabbly Connect to automate the process of adding Nuelink collection posts from Pinterest pins. By following the detailed steps, you can streamline your workflow and enhance your social media marketing efforts.
