Learn how to automate adding LinkedIn leads to SendinBlue using Pabbly Connect with this step-by-step guide. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Accessing Pabbly Connect for LinkedIn and SendinBlue Integration
To start integrating LinkedIn leads with SendinBlue, you need to access Pabbly Connect. Begin by creating a free account on Pabbly Connect, which can be done in just a few minutes. Once registered, log into your account to access the dashboard.
On the dashboard, you will see a blue button labeled ‘Create Workflow.’ Click on this button to initiate the process of setting up your automation. In the workflow creation window, assign a name to your workflow, such as ‘Sync LinkedIn Leads with SendinBlue,’ and click on the ‘Create’ button.
2. Setting Up the Trigger Event in Pabbly Connect
In this step, you will set up the trigger event that initiates the automation. Choose LinkedIn as the application and select the ‘New Lead Generation Form Response’ as the trigger event. This will allow Pabbly Connect to listen for new leads generated from your LinkedIn lead generation forms. using Pabbly Connect
Next, click on the ‘Connect’ button to establish a connection with LinkedIn. You will need to authorize Pabbly Connect to access your LinkedIn account. If you have previously connected your account, you can select the existing connection. Once connected, select the lead form you want to use for this automation. Here’s how to proceed:
  • Select the LinkedIn lead generation form you want to integrate.
  • Ensure your form is linked to a campaign with active advertisements.
  • Click on the ‘Save’ button to finalize your trigger setup.
This setup will ensure that every time a new lead fills out your LinkedIn form, Pabbly Connect will capture that data automatically.
3. Configuring the Action in SendinBlue through Pabbly Connect
After setting up the trigger, the next step is to configure the action in SendinBlue. In the action window, select SendinBlue as the application and choose the ‘Create Contact’ action event. This allows you to add the captured lead data directly into your SendinBlue contacts. using Pabbly Connect
To connect Pabbly Connect with SendinBlue, you will need to provide your SendinBlue API key. You can generate this key by logging into your SendinBlue account and navigating to the API Keys section. Once you have the key, paste it into Pabbly Connect and click on ‘Save’ to establish the connection. Then, map the fields from your LinkedIn lead form to the corresponding fields in SendinBlue. The mapping process includes:
  • Selecting the appropriate list in SendinBlue where the leads will be added.
  • Mapping the email address, first name, and last name fields from LinkedIn to SendinBlue.
  • Clicking on ‘Save and Send Test Request’ to verify the connection.
This step will ensure that all new leads are automatically added to your SendinBlue contact list, streamlining your follow-up process.
4. Testing the Integration Between LinkedIn and SendinBlue
Once the action has been configured, it’s crucial to test the integration to ensure everything works correctly. Go back to your LinkedIn lead generation form and submit a test entry using dummy details. After submission, Pabbly Connect will receive the lead data. using Pabbly Connect
Check your Pabbly Connect dashboard to see if the lead data has been captured successfully. You should see the details such as name, email address, and phone number displayed in the response section. If the data appears as expected, it indicates that the integration is functioning correctly. If not, revisit the mapping and connection settings to troubleshoot any issues.
5. Automating Your Lead Management with Pabbly Connect
With the integration successfully tested, you can now automate your lead management process. Every time a new lead fills out your LinkedIn form, Pabbly Connect will automatically add that lead to your SendinBlue account. This automation saves you time and effort, allowing you to focus on nurturing your leads instead of manual data entry. using Pabbly Connect
Keep in mind that Pabbly Connect checks for new leads every 10 minutes, so you may need to wait briefly to see new entries in SendinBlue. This seamless integration ensures that your email marketing efforts can begin immediately after a lead is generated. To enhance this process further, consider exploring other automation opportunities within Pabbly Connect to optimize your business workflows.
In this tutorial, we explored how to use Pabbly Connect to automate adding LinkedIn leads to SendinBlue. By following the steps outlined, you can streamline your lead management process and enhance your email marketing efforts effortlessly. Automate your workflows today and save valuable time!
