Learn to seamlessly integrate LinkedIn Leads with Mailmodo using Pabbly Connect. Follow our step-by-step tutorial to automate contact creation. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To begin integrating LinkedIn Leads with Mailmodo, first, access Pabbly Connect by visiting its website. If you are a new user, you can sign up for free and receive 100 tasks monthly. Existing users can simply log in to their accounts.
Once logged in, you will see various Pabbly applications. For this integration, click on Pabbly Connect to start creating your workflow. This platform will allow you to automate the process of adding new leads from LinkedIn directly to Mailmodo.
After accessing Pabbly Connect, click on the ‘Create Workflow’ button. You will need to name your workflow, for example, ‘LinkedIn Leads to Mailmodo as Contacts.’ Choose the folder where you want to save it and click ‘Create’ to proceed.
  • Select the desired folder for saving.
  • Click ‘Create’ to open the workflow window.
This window is crucial as it includes trigger and action settings. Here, you will set LinkedIn Leads as the trigger application and Mailmodo as the action application. Understanding these components is essential for a successful automation process using Pabbly Connect.
3. Set Up Trigger for LinkedIn Leads
In the workflow window, select LinkedIn Lead Gen Forms as your trigger application. Choose the trigger event as ‘New Lead in Form Response.’ This will ensure that every time a new lead is submitted, your workflow gets triggered.
Next, you will need to connect your LinkedIn account. Click on ‘Connect’ and either select an existing connection or create a new one. Follow the prompts to authenticate your LinkedIn account with Pabbly Connect. Once connected, select the specific lead form you want to use.
4. Configure Action to Add Contacts in Mailmodo
After setting up the trigger, it’s time to configure the action. Select Mailmodo as the action application and choose the action event as ‘Add Contact to List.’ Click ‘Connect’ to link your Mailmodo account with Pabbly Connect.
  • Input your Mailmodo API Key for authentication.
  • Map the required fields such as email, first name, last name, and phone number.
  • Ensure that the list name is correctly specified.
This setup allows Pabbly Connect to automatically add new leads as contacts in Mailmodo, streamlining your lead management process effectively.
5. Test and Verify the Integration
Once everything is set up, it’s crucial to test the workflow. Submit a test lead through your LinkedIn lead form to ensure that Pabbly Connect captures the response and creates a contact in Mailmodo. Monitor the workflow to confirm that the contact appears correctly.
If successful, you will see the new contact listed in your Mailmodo account with all the details you mapped earlier. This confirms that your integration is working as intended, allowing for seamless lead management from LinkedIn to Mailmodo.
In this tutorial, we explored how to use Pabbly Connect to integrate LinkedIn Leads with Mailmodo. By following these steps, you can automate the process of adding new leads as contacts effortlessly, enhancing your lead management efficiency.
