Learn how to integrate LinkedIn leads into GoHighLevel CRM seamlessly using Pabbly Connect. Follow our step-by-step guide for automation. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Setting Up Pabbly Connect for LinkedIn and GoHighLevel Integration
The first step to integrate LinkedIn leads into GoHighLevel CRM is accessing Pabbly Connect. Start by creating a free account on Pabbly Connect, which allows you to automate workflows between various applications.
Once logged in, navigate to the dashboard and click on the blue button labeled ‘Create Workflow’. Here, you can name your workflow, for instance, ‘Sync LinkedIn Leads with GoHighLevel CRM’, and then click ‘Create’. This sets the stage for the integration process.
2. Configuring the Trigger Event in Pabbly Connect
In this step, you will configure the trigger event in Pabbly Connect. Select ‘LinkedIn Lead Generation Form’ as your trigger application. Next, choose the event ‘New Lead Generation Form Response’. This means every time a new lead is submitted via LinkedIn, it will trigger this workflow.
- Click on ‘Connect’ and then ‘Add New Connection’.
- Authorize your LinkedIn account to allow Pabbly Connect access.
- Select the specific lead generation form you want to use.
After successfully setting up the trigger, you will see the details of the lead form response captured. This confirms that Pabbly Connect is correctly receiving data from LinkedIn.
3. Setting Up the Action Event for GoHighLevel CRM
Next, you need to configure the action event to send the captured leads to GoHighLevel CRM via Pabbly Connect. Search for the ‘Lead Connector V2’ as your action application. This is the latest version of the GoHighLevel CRM integration.
Select ‘Create Contact’ as the action event. This will allow you to create a new contact in your GoHighLevel CRM whenever a new lead is received from LinkedIn.
- Click on ‘Connect’ and select your GoHighLevel account.
- Map the fields from LinkedIn to GoHighLevel, such as first name, last name, email, and phone number.
- Click ‘Save and Send Test Request’ to check if the integration works.
After testing, verify that the new contact appears in your GoHighLevel CRM. This confirms that the integration via Pabbly Connect is functioning correctly.
4. Testing the Integration with Dummy Leads
To ensure everything is set up correctly, it’s time to test the integration using dummy data. Go to your LinkedIn lead generation form and submit a test entry using fictitious details. using Pabbly Connect
Once you submit the form, Pabbly Connect will capture this data and process it in the background. Check the response received in Pabbly Connect to confirm that the details are correctly captured.
In your GoHighLevel CRM, refresh the contacts section to see if the new lead has been added. This will provide a clear indication that the automation is working as intended, allowing you to sync LinkedIn leads seamlessly.
5. Conclusion: Automate Your LinkedIn Lead Management
Integrating LinkedIn leads into GoHighLevel CRM using Pabbly Connect simplifies your lead management process significantly. Once set up, this automation ensures that every lead submitted through your LinkedIn form is automatically added to your CRM without manual intervention.
This setup not only saves time but also helps in maintaining a consistent flow of leads into your CRM, enhancing your marketing efforts. With Pabbly Connect, you can now focus on converting leads rather than managing them.
In this tutorial, you learned how to use Pabbly Connect to automate the process of adding LinkedIn leads to GoHighLevel CRM, ensuring efficiency and accuracy in your lead management.
