Learn how to automate adding labels in Trello cards from ActiveCampaign contacts using Pabbly Connect. Step-by-step tutorial for seamless integration. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To automate adding labels in Trello cards from ActiveCampaign contacts, first access Pabbly Connect. This platform enables seamless integration between various applications.
Log in to your existing Pabbly Connect account or sign up for free to get started. Once signed in, navigate to the dashboard where you can create a new workflow for the integration.
In this step, you will create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button located in the top right corner of the dashboard.
Give your workflow a name, such as ‘Add Label in Trello Card from ActiveCampaign Contact,’ and save it in an appropriate folder. This will help in organizing your automations effectively.
  • Click on ‘Create Workflow’.
  • Select a suitable folder for saving.
After creating the workflow, you will see the trigger and action setup window. This is crucial for defining how Pabbly Connect will automate the process.
Now, set up the trigger application in Pabbly Connect. Select ActiveCampaign as the trigger app and choose the event ‘Contact Added’. This means the automation will trigger whenever a new contact is added in ActiveCampaign.
Next, set Trello as the action application. Choose the action event as ‘Add Label to Card’. This indicates that once a new contact is added, a label will be added to the corresponding Trello card.
  • Select ActiveCampaign as the trigger application.
  • Choose ‘Contact Added’ as the trigger event.
  • Select Trello as the action application.
  • Choose ‘Add Label to Card’ as the action event.
This setup allows Pabbly Connect to automate the process effectively.
4. Connecting ActiveCampaign and Trello in Pabbly Connect
To connect ActiveCampaign with Pabbly Connect, input the API key and URL from your ActiveCampaign account. Navigate to the settings in ActiveCampaign to find these details.
After entering the API key and URL in Pabbly Connect, click on ‘Save’ to establish the connection. Once the connection is successful, repeat the process for Trello by providing the necessary API key and token.
Copy the API key from ActiveCampaign settings. Paste the API key in Pabbly Connect. Repeat the process for Trello API key and token.
After connecting both applications, your Pabbly Connect workflow is now ready to capture contacts and add labels in Trello automatically.
5. Testing the Integration in Pabbly Connect
To ensure everything is working, conduct a test by creating a new contact in ActiveCampaign. Fill out the contact form and submit it. This will trigger the workflow in Pabbly Connect.
Once the contact is created, check Pabbly Connect to see if the contact details are captured. If successful, the label should be added to the corresponding Trello card automatically.
Monitor your Trello board to verify that the label has been added correctly. This confirms that the integration between ActiveCampaign and Trello through Pabbly Connect is functioning as intended.
This tutorial demonstrated how to automate adding labels in Trello cards from ActiveCampaign contacts using Pabbly Connect. By following these steps, you can enhance your workflow efficiency and streamline your processes.
