Learn how to automate adding labels in Trello cards from ActiveCampaign contacts using Pabbly Connect. Step-by-step guide with detailed instructions. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start using Pabbly Connect, first, access the platform by signing in. If you are new, you can create an account and get 100 free tasks monthly. Pabbly Connect is the central hub that will automate the process of adding labels to Trello cards based on ActiveCampaign contacts. using Pabbly Connect
Once logged in, navigate to the dashboard. Click on the ‘Create Workflow’ button in the top right corner. In the dialog that appears, name your workflow ‘Add Label in Trello Card from ActiveCampaign Contact’ and select the appropriate folder for organization. Click on ‘Create’ to proceed.
2. Configuring Trigger Event in Pabbly Connect
In this step, you will set up the trigger event using Pabbly Connect. Select ActiveCampaign as your trigger application. The trigger event will be set to ‘Contact Added,’ which means this workflow will be initiated whenever a new contact is created in ActiveCampaign. using Pabbly Connect
- Select ‘ActiveCampaign’ from the trigger application options.
- Choose ‘Contact Added’ as the trigger event.
- Click on ‘Connect’ to link your ActiveCampaign account with Pabbly Connect.
Next, you will need to enter your API key and URL from ActiveCampaign to establish this connection. Follow the instructions provided in Pabbly Connect to obtain these details. Once connected, you can proceed to set up the action event.
3. Setting Up Action Event to Add Labels in Trello
After configuring the trigger, the next step is to set up the action event in Pabbly Connect. Select Trello as your action application. The action event will be ‘Add Label to Card,’ which allows you to automatically add a label to the Trello card associated with the new ActiveCampaign contact. using Pabbly Connect
To connect Trello with Pabbly Connect, you will need to enter your Trello API key and token. Access these by logging into your Trello account and navigating to the developer API keys section. Once you have these details, return to Pabbly Connect and enter them to establish the connection.
- Select the board where the card is located.
- Map the card details by searching for the card associated with the contact.
- Choose the label you want to add, such as ‘High Priority.’
Once you have completed these steps, click on ‘Save and Send Test Request’ to ensure everything is functioning correctly. You should see a confirmation indicating that the label was successfully added to the Trello card.
4. Testing the Integration Between ActiveCampaign and Trello
To verify that your integration works as intended, perform a test by creating a new contact in ActiveCampaign. Fill out the contact form with necessary details such as name and email. After submission, check Pabbly Connect to see if the contact details were captured correctly. using Pabbly Connect
If the integration is set up properly, you should see the new contact information appear in Pabbly Connect’s response section. This confirms that the trigger event is functioning correctly, and the data is being transferred from ActiveCampaign to Pabbly Connect.
Next, go to your Trello board and check if the label has been added to the corresponding card. If you see the label applied as expected, your integration is complete and working seamlessly. This automation ensures that every new contact in ActiveCampaign will automatically have a label added in Trello, streamlining your workflow.
5. Conclusion: Automating Your Workflow with Pabbly Connect
In this tutorial, we explored how to use Pabbly Connect to integrate ActiveCampaign and Trello. By setting up a trigger for new contacts and an action to add labels in Trello, you can automate your workflow efficiently. This integration not only saves time but also enhances productivity by ensuring that your Trello cards are always up to date with the latest contact information from ActiveCampaign.
With Pabbly Connect, you can automate various tasks across different applications, making your processes smoother and more efficient. Start leveraging Pabbly Connect today to enhance your project management and CRM workflows.
