Learn how to integrate Stripe Payment and Flodesk using Pabbly Connect to automate subscriber management based on payment events. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To start the integration process, you need to access Pabbly Connect. This platform allows you to automate workflows between different applications, specifically Stripe Payment and Flodesk.
First, go to the Pabbly website and either sign up for a new account or log in if you already have one. Once logged in, navigate to the Pabbly Connect dashboard by clicking on the ‘Access Now’ button. This dashboard will be your workspace for creating workflows.
Now that you are in the Pabbly Connect dashboard, it’s time to create a new workflow. Click on the ‘Create Workflow’ button and name your workflow according to your integration goal, such as ‘Add Flodesk Subscriber in Segment Based on Stripe Payment’. using Pabbly Connect
  • Define your trigger application as Stripe.
  • Set the trigger event to ‘Checkout Completed’.
After defining the trigger, you will also need to set up the action application, which will be Flodesk. This step is crucial as it determines what happens when the trigger event occurs.
3. Connecting Stripe in Pabbly Connect
To connect Stripe with Pabbly Connect, you will need to copy the webhook URL provided in the trigger setup. This URL will be used to receive payment data from Stripe.
Go to your Stripe dashboard, navigate to the ‘Developers’ section, and select ‘Webhooks’. Here, click on ‘Add Endpoint’ and paste the copied webhook URL. Set the event to ‘Checkout Session Completed’ to ensure that every completed payment triggers the workflow.
4. Setting Up Flodesk to Add Subscribers
With Stripe connected, the next step is to set up Flodesk in your Pabbly Connect workflow. Choose the action event as ‘Create/Update Subscriber’ to add new subscribers automatically based on Stripe payment details.
  • Map the email address received from Stripe to the email field in Flodesk.
  • Include first name and last name fields, mapping them from the Stripe response.
  • Decide if you want to send a confirmation email to the subscriber.
After mapping all necessary fields, save the action setup. This will create a new subscriber in Flodesk every time a payment is completed in Stripe.
5. Adding Subscriber to a Segment in Flodesk
Finally, to ensure that your newly added subscribers are organized, you can add them to a specific segment in Flodesk. In your Pabbly Connect workflow, add another action step and select Flodesk again.
Choose the action event as ‘Add Existing Subscriber to Segment’. Here, you will need to map the subscriber’s email and select the segment where you want the subscriber to be added. This ensures that your email marketing efforts are targeted and effective.
Once the mapping is complete, click on ‘Save and Test’ to finalize the workflow. This will confirm that the subscriber has been added to the specified segment successfully.
In this tutorial, you learned how to use Pabbly Connect to automate the process of adding Flodesk subscribers based on Stripe payments. By following these steps, you can streamline your subscriber management and enhance your email marketing efforts efficiently.
