Learn how to integrate Stripe Payment with Flodesk using Pabbly Connect to automate subscriber management based on payment events. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To begin integrating Stripe Payment with Flodesk, first access Pabbly Connect. This platform allows you to automate tasks between various applications seamlessly. If you don’t have an account, you can easily sign up for free and get started.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can manage your workflows and create new integrations. Click on the ‘Create Workflow’ button to start setting up your automation.
After accessing the dashboard, the next step is to create a new workflow. Name your workflow something descriptive, like ‘Add Flodesk Subscriber in Segment Based on Stripe Payment’. Select a folder to save this workflow for better organization. using Pabbly Connect
- Enter your workflow name.
- Select the appropriate folder for organization.
Now, you’ll see two sections: Trigger and Action. The Trigger is the event that starts the workflow, while Action is what happens as a result. Here, select Stripe as the trigger application and set the event to ‘Checkout Completed’.
3. Connecting Stripe with Pabbly Connect
The next step is connecting Stripe to Pabbly Connect. You will need to copy the webhook URL provided by Pabbly Connect and add it to your Stripe account. This URL allows Stripe to send payment details to Pabbly Connect.
In your Stripe dashboard, navigate to the Developers section and find the Webhooks option. Click on ‘Add Endpoint’ and paste the copied URL into the endpoint URL field. Provide a description, select the ‘Checkout Session Completed’ event, and then save the endpoint.
- Go to the Stripe Developers section.
- Select Webhooks and click ‘Add Endpoint’.
- Paste the webhook URL and select the event.
After saving the endpoint, return to Pabbly Connect. The platform will be waiting for a response from Stripe, which you can trigger by completing a test payment.
4. Testing the Integration with a Test Payment
To test the integration, you need to make a test payment through Stripe. Use the payment link associated with your product to complete the checkout process. Fill in the required details, including email, name, and payment information. using Pabbly Connect
Once the payment is completed, Pabbly Connect will receive the response from Stripe. This will include all relevant payment details, such as the customer’s name, email, and address. Make sure to verify that the response includes all necessary data.
Complete the payment using the provided payment link. Check Pabbly Connect for the received response. Verify that all customer details are captured correctly.
After confirming that the payment details are received, you can proceed to set up the action to add the subscriber in Flodesk.
5. Adding Subscriber in Flodesk Using Pabbly Connect
Now that you have the payment details, it’s time to add the subscriber in Flodesk. In the action section of Pabbly Connect, select Flodesk as the application and choose the action event to ‘Create/Update Subscriber’. Connect your Flodesk account by entering your email and password.
Next, you will map the fields with the data received from Stripe. This includes the subscriber’s email, first name, last name, and other details. Make sure to select the option to send an opt-in confirmation email if needed.
Select Flodesk as the action application. Map the fields with the Stripe payment data. Choose whether to send an opt-in confirmation email.
Finally, save your workflow and test the action to ensure that the subscriber is added successfully to Flodesk. You can also add an additional action to place the subscriber in a specific segment based on the payment.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Stripe Payment with Flodesk for automated subscriber management. By following these steps, you can streamline your email marketing efforts based on payment events.
