Learn how to integrate Facebook leads into Google Sheets for your leather business using Pabbly Connect. Step-by-step guide for seamless automation. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Accessing Pabbly Connect for Your Leather Business
To automate adding Facebook leads to Google Sheets for your leather business, you first need to access Pabbly Connect. This platform allows you to integrate various applications seamlessly. Start by visiting the Pabbly Connect website, where you can sign up for a new account or log in if you are an existing user.
Once you are logged in, you will see the Pabbly Connect dashboard. Here, you can create new workflows that automate your processes. This is where the integration between Facebook leads and Google Sheets will take place, making it essential for your leather business automation.
To create a workflow, click on the ‘Create Workflow’ button located in the top right corner of the dashboard. You will need to name your workflow, such as ‘Leather Facebook Leads to Google Sheets’. This name helps you identify your workflow later. using Pabbly Connect
  • Click on ‘Create’ after naming your workflow.
  • Select ‘Facebook Lead Ads’ as your trigger application.
  • Set the trigger event to ‘New Lead Instant’.
After setting up your trigger, Pabbly Connect will automatically capture new leads generated from your Facebook ads, which is vital for your leather business.
Next, you need to connect your Facebook Lead Ads to Pabbly Connect. Click on ‘Connect’ and select ‘Add New Connection’. If you have previously connected your Facebook account, you can select that existing connection.
Now, select your Facebook page and the lead form you want to use. For instance, if your page is named ‘Only Leather’, choose that page and select the corresponding lead form. This setup ensures that only leads from your specified form are captured by Pabbly Connect.
4. Setting Up Google Sheets Integration
After configuring the trigger, the next step is to set the action application to Google Sheets. Choose ‘Google Sheets’ as your action application and select ‘Add New Row’ as the action event. This means that every time a new lead is generated, the details will be automatically added to your Google Sheets. using Pabbly Connect
Click on ‘Connect’ to build a new connection with Google Sheets. If you have already connected your Google account, you can select that existing connection. Sign in with your Google account and grant access to Pabbly Connect to secure your data.
  • Select the spreadsheet where you want to store the leads.
  • Choose the specific sheet, such as ‘Sheet1’.
  • Map the data fields from Facebook leads to your Google Sheets.
Mapping ensures that the correct information is placed in the right columns, making data management easier for your leather business.
5. Testing the Integration
After setting up the integration, it’s crucial to test whether everything is working correctly. You can do this by submitting a test lead through the Facebook Lead Ads testing tool. Ensure you delete any existing leads before creating a new one, as this is a requirement for testing. using Pabbly Connect
Once you submit a test lead, return to Pabbly Connect to check if the lead details appear in your Google Sheets. If everything is set up correctly, you should see the new lead’s information in the specified sheet.
This testing step is vital to confirm that your leather business automation is functioning as intended, allowing you to focus on other aspects of your business.
In this tutorial, we explored how to use Pabbly Connect to automate the process of adding Facebook leads to Google Sheets for your leather business. By setting up triggers and actions, you can streamline your lead management effectively. This integration not only saves time but also enhances your workflow.
