Learn how to seamlessly integrate Facebook Leads into Google Sheets for the Healthcare Equipments Industry using Pabbly Connect. Step-by-step guide included. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To add Facebook leads to Google Sheets for the healthcare equipments industry, you will need to access Pabbly Connect. Start by signing in to your existing account or create a new one by clicking on the ‘Sign Up for Free’ button. With Pabbly Connect, you can utilize 100 tasks for free every month, making it easy to automate your workflow.
Once logged in, navigate to the applications page and click on ‘Access Now’ under Pabbly Connect. This will direct you to your dashboard where you can create a new workflow to integrate Facebook and Google Sheets.
After accessing Pabbly Connect, you will need to create a new workflow. Click on the ‘Create Workflow’ button located in the top right corner of your dashboard. Name your workflow appropriately, such as ‘Add Facebook Leads to Google Sheets,’ and select a folder to save it in, like ‘Facebook Lead Ads’.
Now, you will see the trigger and action setup window. In this section, define your trigger application as Facebook and the trigger event as ‘New Lead Instant’. This means that every time a new lead is generated through Facebook lead ads, the workflow will automatically initiate. Next, set Google Sheets as your action application with the action event set to ‘Add a New Row’.
Connecting Facebook Leads to Pabbly Connect
To establish a connection between Facebook leads and Pabbly Connect, click on the ‘Connect’ button next to your trigger application. You will be prompted to log into your Facebook account if you haven’t already. Once logged in, authorize the connection, and you will see a successful authorization message.
Next, you need to select the Facebook page and lead gen form associated with your medical equipment business. For this, choose the page named ‘Life Care Medical Equipments’ and the lead gen form titled ‘Medical Equipments’ from the dropdown options. After selecting these, click on ‘Save and Send Test Request’ to proceed with the integration.
Testing the Integration with Pabbly Connect
After setting up the connection, it’s time to test the integration. Pabbly Connect will wait for a webhook response, indicating that it’s ready to capture data. To send a test lead, go to the Meta for Developers page, select your page and lead gen form, and fill in the required details such as email, full name, and phone number. Once completed, submit the form. using Pabbly Connect
Upon submission, Pabbly Connect will capture the test lead data, displaying the email ID, full name, phone number, and other details. This confirms that the integration is functioning correctly and ready to automate the process of adding new leads to Google Sheets.
Adding Leads to Google Sheets Using Pabbly Connect
To finalize the integration, you need to connect Pabbly Connect with Google Sheets. Click on the ‘Connect’ button in the action window and sign in with your Google account. Authorize the connection, allowing Pabbly Connect to access your Google Sheets.
Next, select the spreadsheet you created for Facebook leads, titled ‘Facebook Leads New’. Ensure that the selected sheet is set to ‘Sheet1’. Now, proceed to map the lead details from the Facebook response to the corresponding columns in Google Sheets: lead email, lead name, and phone number. Finally, click on ‘Save and Send Test Request’ to add the lead details to your Google Sheet.
Using Pabbly Connect, you can efficiently automate the process of adding Facebook leads to Google Sheets for the healthcare equipments industry. This integration streamlines your workflow, ensuring that every new lead is captured accurately and promptly.
