Learn how to integrate Facebook Leads with Google Sheets for your Dry Fruits Business using Pabbly Connect. Follow our step-by-step tutorial for seamless automation. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To begin the integration process, you need to access Pabbly Connect. Start by opening your web browser and navigating to Pabbly’s website. If you don’t have an account, you can sign up for free, which allows you to utilize 100 tasks monthly at no cost.
Once logged in, click on the ‘Access Now’ button under Pabbly Connect. This will direct you to the dashboard, where you can create workflows that facilitate the integration of Facebook Leads into Google Sheets.
In this section, you will create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button and name your workflow, such as ‘Add Facebook Leads to Google Sheets for Dry Fruits Business.’ Select the folder where you want to save this workflow.
- You will see two sections: Trigger and Action.
In the Trigger section, choose ‘Facebook Lead Ads’ as your application. The trigger event will be ‘New Lead Instant.’ This setup ensures that whenever a new lead is generated on Facebook, the workflow will be initiated.
After setting up the trigger, you need to connect your Facebook Lead Ads to Pabbly Connect. Click on ‘Connect’ and then ‘Add New Connection.’ You will be prompted to log into your Facebook account and grant permission for Pabbly Connect to access your lead data.
Once connected, select your Facebook page, which in this case is ‘Tara Dry Fruit Company,’ and choose the lead generation form you want to use. This form should contain the necessary fields like full name, email, and phone number.
- Ensure your lead generation form is live before proceeding.
- Click on ‘Save and Send Test Request’ to confirm the connection.
After saving, you will need to create a sample lead submission to test if the connection works correctly. Use the Meta for Developers tool to fill in the form and submit a lead.
4. Setting Up Google Sheets Action in Pabbly Connect
With the trigger set up, you now need to configure the Action step in Pabbly Connect. Select ‘Google Sheets’ as your action application and choose ‘Add New Row’ as the action event. This action will allow you to automatically add new leads to your spreadsheet.
Next, connect your Google Sheets account by clicking ‘Connect’ and allowing Pabbly Connect to access your Google Sheets. After a successful connection, select the spreadsheet titled ‘Facebook Leads’ and the sheet where you want to add the data.
Map the fields from Facebook Lead Ads to the corresponding columns in Google Sheets. Ensure that full name, email, and phone number are correctly mapped.
Once mapping is complete, click on ‘Save and Send Test Request’ to verify that the data is being added correctly to your Google Sheets.
5. Verifying Integration Success
To confirm that your integration between Facebook Lead Ads and Google Sheets via Pabbly Connect is successful, check your Google Sheets for the new lead entry. You should see the details of the lead you submitted earlier reflected in the sheet.
To further test, you can delete the previous lead and submit a new one through the Facebook lead form. Refresh your Google Sheets, and you should see the new entry appear instantly, demonstrating the seamless automation.
This integration allows you to manage and track leads efficiently, ensuring that your dry fruits business can respond to potential customers promptly. With Pabbly Connect, you can automate many more processes, enhancing your business operations.
In this tutorial, we explored how to use Pabbly Connect to integrate Facebook Leads into Google Sheets for your dry fruits business. By following the exact steps outlined, you can automate lead management and ensure that your leads are recorded accurately and efficiently.
Utilizing Pabbly Connect not only saves time but also enhances your ability to respond quickly to new leads, making your business more competitive and organized.
