Learn how to automate adding AWeber subscribers to FunnelKit using Pabbly Connect. Step-by-step guide with detailed instructions and UI elements. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Setting Up Pabbly Connect for AWeber and FunnelKit Integration
To begin the process of adding AWeber subscribers to FunnelKit as contacts, you need to set up Pabbly Connect. First, sign up for a free account on Pabbly Connect. Once logged in, navigate to the dashboard where you will create a new workflow.
Click on the ‘Create Workflow’ button, then name your workflow something like ‘AWeber to FunnelKit’. From the dropdown, select the appropriate folder for your workflow. After this, click on ‘Create’. Now, you will see two windows: the trigger window and the action window, which are essential for setting up the automation.
2. Connecting AWeber to Pabbly Connect
In the trigger window, you will connect your AWeber account to Pabbly Connect. Search for AWeber in the ‘Choose App’ section. Next, select the trigger event labeled ‘New Subscriber in List’ from the dropdown menu. Click on ‘Connect’ and then choose ‘Add New Connection’ to link your AWeber account.
  • Click on the ‘Connect with AWeber’ button.
  • Log into your AWeber account and allow access.
  • Select the account you wish to use from the dropdown.
  • Choose the List ID from which you want to receive subscriber details.
After selecting the necessary details, click on ‘Receive and Send Test Request’. This action will retrieve the most recent subscriber’s details from AWeber into Pabbly Connect. You should see the subscriber’s name, email, mobile number, and city in the response.
3. Adding the Subscriber as a Contact in FunnelKit
Next, we will add the subscriber to FunnelKit using Pabbly Connect. In the action window, search for FunnelKit and select it. Then, choose the action event ‘Create Contact’ from the dropdown menu. Click on ‘Connect’ and select ‘Add New Connection’. You will need to enter your FunnelKit API key and website URL to establish the connection.
To obtain the API key, go to your WordPress site where FunnelKit is installed. Under the FunnelKit Automations section, navigate to Settings and click on the ‘Pabbly API’ button. Generate a new API key by selecting the permission type and user, then copy this key back to Pabbly Connect. Paste the API key and your site URL, then click ‘Save’.
4. Mapping Data Between AWeber and FunnelKit
After connecting FunnelKit, you will now map the data from the AWeber trigger to the FunnelKit action. In the email field, select the email address of the new subscriber from the AWeber response. For the first and last name, since you have the full name, you will use the Text Formatter feature in Pabbly Connect to split the name into two parts.
  • Add an Action step and select Text Formatter.
  • Choose ‘Split Text’ as the action event.
  • Map the full name response and set the separator as a space.
After mapping the first and last names, select the mobile number from the AWeber responses. You can also choose a status for the subscriber, add tags, and select the list in FunnelKit where the contact should be added. Finally, click ‘Save and Send Test Request’ to complete the setup.
5. Testing the Automation in Real-Time
Once you have configured the workflow in Pabbly Connect, it’s time to test the automation. Go to your AWeber account and add a new subscriber using your subscription form. For instance, enter the name ‘Demo User’, an email address, a mobile number, and a city like ‘Delhi’. Submit the form to add this subscriber.
After submitting, refresh your AWeber subscribers page to confirm the new entry. Wait for about 10 minutes as Pabbly Connect checks for new subscribers every 10 minutes. After this time, check your FunnelKit account under the contacts section to verify that the new subscriber has been added with the same details.
This tutorial demonstrated how to add AWeber subscribers to FunnelKit as contacts using Pabbly Connect. By following the steps outlined, you can automate the process efficiently and ensure that your subscriber data is synchronized across platforms.
