Learn how to create ActiveCampaign contacts for CopeCart payments using Pabbly Connect with tags. Step-by-step guide for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To create ActiveCampaign contacts for CopeCart payments, you will first need to access Pabbly Connect. This platform allows you to automate the integration process between various applications seamlessly.
Begin by visiting the official Pabbly Connect website. Sign in to your existing account or create a new one if you’re a first-time user. Pabbly Connect offers 100 free tasks monthly for new users, making it easy to get started.
Once logged into Pabbly Connect, you will need to create a new workflow to automate the process. Click on the ‘Create Workflow’ button on the dashboard.
- Name your workflow, for example, ‘Create ActiveCampaign Contact for CopeCart Payment with Tags.’
- Select a folder to save your workflow, such as ‘ActiveCampaign Automations.’
After entering the name and selecting the folder, click ‘Create’ to establish your workflow. This will set the stage for defining the trigger and action steps necessary for your automation.
3. Setting Up Trigger and Action Steps
In this step, you will define the trigger and action for your workflow in Pabbly Connect. The trigger application will be CopeCart, and the action application will be ActiveCampaign.
- Select ‘CopeCart’ as your trigger application.
- Choose ‘Instant Payment Notification’ as the trigger event.
After setting the trigger, Pabbly Connect will provide a unique webhook URL. Copy this URL, as it will be used to connect CopeCart with Pabbly Connect. Ensure you follow the instructions provided to set up this connection properly.
4. Connecting CopeCart with Pabbly Connect
To link CopeCart with Pabbly Connect, log into your CopeCart account and navigate to the settings. Under the IP and connections section, create a new integration.
Select ‘Generic’ as the integration type. Paste the webhook URL you copied from Pabbly Connect into the notification URL field.
After saving the integration, link it to the product you are selling in CopeCart. This setup ensures that every payment processed will trigger the webhook, sending customer details to Pabbly Connect.
5. Integrating ActiveCampaign with Pabbly Connect
With CopeCart connected, the next step is to set up the action in Pabbly Connect for ActiveCampaign. Select ActiveCampaign as your action application and choose ‘Create or Update Contact’ as the action event.
To connect ActiveCampaign, you will need your API key and URL. These can be found in your ActiveCampaign account under the developer settings. Copy and paste these into Pabbly Connect, ensuring to follow the instructions about the URL format.
Once connected, map the fields from the CopeCart payment data to the corresponding fields in ActiveCampaign, such as first name, last name, email, and phone number. Additionally, you can add tags to the contact, like ‘CopeCart,’ for better organization.
In this tutorial, we explored how to create ActiveCampaign contacts for CopeCart payments using Pabbly Connect. This integration allows for seamless automation, ensuring that every payment results in a new contact being created in ActiveCampaign efficiently.
