Learn how to use Pabbly Connect to automatically generate and post tweets from RSS feeds using Google Gemini. Step-by-step tutorial included. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Accessing Pabbly Connect for Tweet Automation
To create viral AI generated tweets using RSS feeds, you first need to access Pabbly Connect. This platform enables seamless integration between various applications, including Google Gemini and Twitter.
Visit the Pabbly Connect homepage by entering the URL in your browser. If you are a new user, click on ‘Sign up for free’ to create an account and receive 100 free tasks monthly. Existing users can simply log in.
Once logged into Pabbly Connect, you will be on the dashboard. Click on ‘Create Workflow’ to start setting up the automation process for tweets.
- Name your workflow, for example, ‘Automatically Generate Tweets Using Google Gemini from RSS Feeds’.
- Select the appropriate folder for your workflow.
After creating the workflow, you will see options for setting triggers and actions. The trigger will be the RSS feed, and the action will be the tweet generation through Google Gemini.
3. Setting Up RSS Trigger in Pabbly Connect
For the trigger step, select ‘RSS by Pabbly’. This feature helps capture RSS feeds automatically. Choose the trigger event ‘New Item in Feed’ to activate the workflow whenever a new RSS feed is available.
Enter the feed URL from NDTV RSS feeds for technology news. Set the polling time to 1 hour, which is how often Pabbly Connect checks for updates. After entering the feed URL, click on ‘Save and Send Test Request’ to check if the connection is successful.
- Copy the URL of the technology news RSS feed from NDTV.
- Paste it into the feed URL field in Pabbly Connect.
- Select the filter type as ‘Default’ for simplicity.
Upon successful setup, you will receive a response from the RSS feed indicating the latest news, confirming that the integration is working.
4. Generating Tweets Using Google Gemini
After setting up the RSS trigger, the next step is to generate tweets using Google Gemini through Pabbly Connect. Select Google Gemini as the action application and choose the action event ‘Generate Content’. This will convert the RSS feed into engaging tweets.
To establish the connection, you will need to enter your API key from Google Gemini. If you do not have an API key, follow the instructions to generate one from the Google AI Studio.
Log into your Google Gemini account and navigate to the AI Studio. Click on ‘Get API Key’ and create a new key for your project. Copy the API key and paste it into Pabbly Connect.
Once connected, enter the prompt for generating tweets using the feed description. This setup allows for dynamic content generation for each new RSS feed received.
5. Posting Tweets on X (Formerly Twitter)
The final step is to post the generated tweets on your X handle. Select X as the action application and choose the action event ‘Create Tweet’. This ensures that the tweets generated by Google Gemini are posted automatically. using Pabbly Connect
To connect to X, you will need your client ID and client secret from your Twitter Developer account. Follow the provided instructions to retrieve these credentials.
Access the Twitter Developer portal and select your app. Navigate to ‘Keys and Tokens’ to find your client ID and secret. Paste these credentials into Pabbly Connect to authorize the application.
After successfully connecting, map the tweet content generated by Google Gemini and click ‘Save and Send Test Request’. Your tweet will be posted automatically on your X handle, completing the integration process.
This tutorial demonstrates how to automate the process of generating and posting tweets using RSS feeds with Pabbly Connect. By integrating RSS by Pabbly, Google Gemini, and X, you can keep your followers updated with the latest technology news effortlessly.
